Old 03-24-2013, 09:52 PM   #1
rs74
rs74's Avatar
Does anyone run a gear drive in their engines.
I have an older Pete Jackson noisy set that I am debating putting in. I run this one years ago and it is pretty loud. Everyone kept telling me my power steering pump was going out. I also hear some say that if you want the whine then put a supercharger on and don't be a wanna be. Your thoughts?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-24-2013, 10:05 PM   #2
Redcap
Re: Does anyone run a gear drive in their engines.
If I'm going to have that noise, it will only be because of a blower.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 03-24-2013, 10:06 PM   #3
cleansquare
my cousin had one and i just thought it was annoying but he liked it
cleansquare is offline   Reply With Quote
Old 03-24-2013, 10:32 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
The three gear gear drive is about as good as you can get. The idler gear gear drives are garbage with way to much lash.
If you can find an older positive style gear drive with just two gears that's what you get. You have to have the cam company grind the cam lines backwards and the distributor gear and distributor changed. It's old tech but it was the top untill belt drive
A good chain is fine till to 6k rpm before its a jump rope
The three gear drives are sufficient for racing with proper lash
And the belts are just the best but way out there on price
So if you want the gear whine on your daily its not going to hurt nothin and you won't be missing any power the quiet ones are what I recommend though since they won't wear you out otherwise a cloyes true roller will do the job
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-24-2013, 10:39 PM   #5
naphtali5725
naphtali5725's Avatar
Originally Posted by redcap View Post
if i'm going to have that noise, it will only be because of a blower.
x2^^
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 03-24-2013, 10:40 PM   #6
rs74
rs74's Avatar
The one I have is a four gear setup with the idler gears. I have been really leaning towards not using it but have not ruled it out yet. I just wanted to see what others thought about them.
Roy
1987 R10 shortie
Old 03-24-2013, 10:44 PM   #7
naphtali5725
imagine the harmonics of that whine on a long drive down the freeway... brutal
My build thread...
Disabled Veteran
Old 03-24-2013, 10:48 PM   #8
rs74
rs74's Avatar
I used to run it in my 79 cutlass. It never bothered me then but that has been 20 years ago. I will probably just put it up locally for sale. I don't plan on keeping a carbed engine in it too long after it gets done if I have my way about it anyway.
Roy
1987 R10 shortie
Old 03-24-2013, 10:50 PM   #9
meatwagon83
meatwagon83's Avatar
i have a pete jackson in my chevelle, i have had no problems
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 03-24-2013, 11:07 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
They sound like a power steering pump low on fluid.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-24-2013, 11:21 PM   #11
LynnJr
I would run both and don't worry about the noise.
LynnJr is offline   Reply With Quote
Old 03-24-2013, 11:35 PM   #12
bigwheel15
bigwheel15's Avatar
I really looked into running a gear drive when I had my motor built but came to the conclusion that unless you're running a nice lumpy can and have the power to back the noise you're just gonna sound like you have a bad power steering pump.
bigwheel15 is offline   Reply With Quote
Old 03-24-2013, 11:56 PM   #13
bluex
bluex's Avatar
I can't stand mine. It was cool before i drove it 7 hrs to Alabama. im planning on resealing the engine an when i do it's coming out....
bluex is offline   Reply With Quote
Old 03-25-2013, 12:58 AM   #14
meatwagon83
did you say lumpy? here is my chevelle, sorry its so short
http://youtu.be/1CXlYml3ttM
Old 03-25-2013, 06:23 PM   #15
pwradder
pwradder's Avatar
i had one in a pontiac i bought, i pulled it asap. it's all opinion but i think they're annoying.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-25-2013, 07:09 PM   #16
68Timber
I know the pieces fit
68Timber's Avatar
I had a noisy PJ on a K5 once, never regretted a 'performance part' more. For $167.50, everybody and their brother started telling me I needed a new PS pump.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-25-2013, 08:49 PM   #17
northeimcustom
northeimcustom's Avatar
I use one, its the 'quiet' one. You can hear it, but its not super loud. Not like I have stock exhaust either...
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 03-26-2013, 06:38 PM   #18
Pro/StreetPete
Pro/StreetPete's Avatar
Same here !!
"You're only as good as the people you keep around you"
Pro/StreetPete is offline   Reply With Quote
Old 03-26-2013, 08:23 PM   #19
S10Fan
Old Heap Driver
I had one in the first V-8 I stuffed in my S-10, it was cool for about 20 minutes. The 383 went together with a nice timing chain from CompCams.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-26-2013, 09:38 PM   #20
meatwagon83
you guys must have real quite trucks, i have a noisy one and can barely hear it, listen to the video of my car i posted, you cant even hear the thing, bottom line is, if you dont like them, dont get one. but dont complain because i have one!
Old 03-26-2013, 10:05 PM   #21
LynnJr
If you can't handle a little gear drive noise forget about ever owning a blower
Old 03-26-2013, 10:35 PM   #22
Daveyboy1983
I had a noisy one in My '61 Suburban I could never get enough of it!! I like hearing gears whine...Also like the sound of a turbo whistling, but that's just me
Daveyboy1983 is offline   Reply With Quote
Old 03-26-2013, 10:59 PM   #23
68Timber
68Timber's Avatar
There's a big difference between a regular gear drive and one advertised as "noisy". The regular ones aren't very noticeable except to gearheads and they make a higher pitched whine. EVERYONE notices the "noisy" ones and every dude possessing a crescent wrench will tell you your power steering pump is bad because that's exactly what it sounds like. There's no comparing the two. The most obnoxiously loud truck I've ever owned wasn't loud enough to drown out the moan of that noisy Pete Jackson. You couldn't give me another one unless I could sell it.
John
74 Honda Z50 build
Old 03-27-2013, 10:57 AM   #24
bikeman59
Wow! A little sensitive? I don't think anyone was whining about your whiny gears.
Project: 1980 Chevy SWB
DD: 1999 Chevy Tahoe, lifted on 33"s
Toy: 1996 HD FLSTC, custom by me
bikeman59 is offline   Reply With Quote
Old 03-28-2013, 07:11 PM   #25
pwradder
pwradder's Avatar
oh, i've got a supercharger...but thats good noise!
