03-24-2013, 10:23 PM | #1 |
Lunati Retro Fit Hydraulic Roller 60113 New!
Up for sale is a new 60113 retro fit hydraulic roller, Summit sells for 299.00 plus shipping.
220.00 ship Lunati Manufacturer's Part Number:60113 Part Type:Camshafts Product Line:Lunati Hydraulic Roller Tappet Camshafts Summit Racing Part Number:LUN-60113 UPC:090127619889 Cam Style:Hydraulic roller tappet Basic Operating RPM Range:2,800-6,400 Intake Duration at 050 inch Lift:243 Exhaust Duration at 050 inch Lift:251 Duration at 050 inch Lift:243 int./251 exh. Advertised Intake Duration:294 Advertised Exhaust Duration:302 Advertised Duration:294 int./302 exh. Intake Valve Lift with Factory Rocker Arm Ratio:0.560 in. Exhaust Valve Lift with Factory Rocker Arm Ratio:0.565 in. Valve Lift with Factory Rocker Arm Ratio:0.560 int./0.565 exh. Lobe Separation (degrees):110 Computer-Controlled Compatible:No Grind Number:VDSC-294 Valve Springs Required:Yes Quantity:Sold individually. These hydraulic roller tappet cams from Lunati provide the best of both worlds. These aggressive profiles produce more power over a broader rpm range, while providing the benefits of quieter operation and ease of valve lash setting. These cams will get you off the line quicker and on your way to the winner's circle--no wonder they're "The Racer's Choice"! ped! |
03-26-2013, 09:43 PM | #2 |
Re: Lunati Retro Fit Hydraulic Roller 60113 New!
Toodatop
Posted via Mobile Device |
06-09-2013, 07:00 PM | #3 |
hey yo still for sale!
06-15-2013, 07:41 PM | #4 |
nice!
