Pic Request
Anyone have some good shots of the routing of your series trucks brake lines?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Pic Request
Series truck?
Re: Pic Request
73-87 C-10 Shortbed?
Is there a difference when referring to brake lines (legit question as I dont know)...? |
Re: Pic Request
Let me drag some more info out of you.
What are you trying to do? Stock replacement lines on a stock truck? Bending your own lines? Full custom build? Different M/C and prop valve?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-25-2013 at 09:43 AM. |
#5 | |
Re: Pic Request
What are you trying to do? Convert 67 truck to 73-87 setup Clicky Got a couple of pics on a 63 for this thread from txfirefighter. It appears the brake lines mount to inner fender. Was hoping to maybe see if there were some other setups that tuck the lines from the MC to Prop valve inside the frame rail as it looks cleaner to me. Stock replacement lines on a stock truck? Yes I think so. Bending your own lines? No tried that... see link above Full custom build? Yes Different M/C and prop valve? Stock M/C on a 9"booster. Prop valve is machines but looks like the factory as I have them side by side to compare. |
