Wire tucking!
Hi to all. I'm rewiring/ tucking all of my under hood wire on my 64 lwb for a little cleaner look. I have all the harness of my 64 I6 and a complete one from a 78 HEI v8 truck. going to cut down the 78 to make work for the 64. i have already done the headlight harness and added relays into it for a little upgrade. All the info or incite to doing this would be Very helpful.
Posted via Mobile Device |
![]() Join Date: Oct 2010
Re: Wire tucking!
I ran all my wires down the firewally through the hole where the speedo cable normally goes through.
Then I went 'up' to the HEI, oil sending unit, along with temp unit. I also am running a elec speedo so I didn't need that hole. So it worked out perfect. Ran this through the frame rails into the speedo sending unit All my tailight wiring also goes through that hole. As far as my hood turn signals (and an underhood light) I ran them through the firewall. Then tucked them behind the hood brace. I also removed any necessary wiring from the original connectors going through the hole by the left inner fender. I then used one of the empty slots in that connector for my underhood light. The headlight wire was only an on-off, This one ran though the left frame rail I ran two relays to my headlights so of course so I ran a wire going from the battery (mounted with a drop down box behind the cap). So really all you see is the wires coming through the firewall running to the hood brace. I welded and smoothed all the firewall holes
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
Re: Wire tucking!
any pics?
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air. |
Re: Wire tucking!
Well, I only found some pics of the engine bay. It does show where the wiring goes, but it's hard to see. You'll have to study the pictures.
By the way, I said I ran the headlight wiring down through the speedo hole, I forgot, I did run this wire along with another one down the inner fender seal. All other wires went through the speedo hole and ran down the frame rail. All the pics are of the same basic area, but at slightly different angles. --The first pic is just the mess of wires behind the dash. --The second pic shows how I tucked them behind the hood slat (after running them through the hole in the hood brace. --third and forth you can see the only wires that come out of the firewall. ![]() ![]() ![]() ![]()
Re: Wire tucking!
Now that is what I am talking about! Answers and pics, they go together like the smell of burnt rubber and a big block
![]() Posted via Mobile Device |
Re: Wire tucking!
Here's mine I tried to hide wires, heater & AC hoses
![]() Jim ![]() |
Re: Wire tucking!
Now how in the heck did you hide the heater and ac?? And where did you run your wires to keep it so clean??
Re: Wire tucking!
Super sharp 'Sub'!
Looks like you succeeded! Like the clean look
![]() Join Date: Jul 2011
Re: Wire tucking!
This is my 65 C10 I hid most of my wires almost done.
Who Me?
Re: Wire tucking!
Great looking examples!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Wire tucking!
1 thing at a time is progress.
Re: Wire tucking!
My wires for the engine come up the back of the engine. The wires for the headlights etc. run thru conduit imside the frame rail. Being my first one it's not too bad, I have seen a lot of nicer ones. It's time consuming to hide wires, but makes a better product. I still need a better way of seperating my AC heater hoses.
Alan
Philippians 2:14-16 |
#13 |
Re: Wire tucking!
Wow! All of these are alsome looking trucks. Thank you all for all the wisdom you have shared.
#14 |
Re: Wire tucking!
Some real clean work being done.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#15 |
Re: Wire tucking!
Sub'd for future ref! Amazing Work guys!!!!!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
