Old 03-25-2013, 12:04 PM   #1
fun in dirt
fun in dirt's Avatar
205 indicator light switch
I need some help finding a part!
The switch on top of 205 that tells dash light its in 4wd needs replacing, but I can't seem to find one.
On NAPA & other chain parts store websites it comes up the ball-end style switch; I need the plunger style end.
After lots of web search I figured this much out...Old GM# was 14024304 which was discontinued & now #15594176. Some older post (like from '06 & back) on other forums folks seem to have used a Niehoff #DR130T or CarQuest EC TCA3, but none of these #s come up good either.
Only place I have found them is Quad 4x4 for $122-165, but I'm NOT paying that for a light switch; these others folks have given $16-25 for.
From 1980-82 it had the spade terminals & to '87 had the other connector, either one will work.
Anybody go a source?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-28-2013, 04:00 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 205 indicator light switch
I may need one too....
Rich
1972 K5 Blazer CST Click HERE
Old 03-28-2013, 05:41 AM   #3
jjzepplin
jjzepplin's Avatar
Can you just put one of these in any 205 and it will work?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-28-2013, 03:09 PM   #4
fun in dirt
I'm not real sure, but don't think so...something about the shift rail shape being different in older (pre'80?) 205s & won't push the switch in.
So nobody else has need to replace this switch???
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 03-29-2013, 12:35 AM   #5
bilfman
bilfman's Avatar
I just replaced mine, found it here. A little pricy, but hey not a lot of other options! They shipped quick, no worries.
http://www.quad4x4.com/New_Process_NP205_Parts.html
You have to scroll down quite a way.
I just reread your post, I see you found this one as well. That said, it was the only source I came across.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-29-2013, 10:00 AM   #6
obijuan
All GM 205 shift rails are the same. The detent ball will compress the spring and touch the sensor and light up the dash light.
obijuan is offline   Reply With Quote
Old 03-29-2013, 07:50 PM   #7
jjzepplin
jjzepplin's Avatar
I heard they weren't good to know.
