Old 03-25-2013, 12:06 PM   #1
csdineley
csdineley's Avatar
14bsf to 14bff swap?
Hello
I wondering how hard would it be to swap a 14bff into my truck with a 14bsf?
csdineley is offline   Reply With Quote
Old 03-25-2013, 12:21 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 14bsf to 14bff swap?
Just make sure you get one out of a 3/4 ton. Then just unbolt brake lines, drive shaft, and U bolts. It's that easy.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-25-2013, 12:26 PM   #3
csdineley
csdineley's Avatar
I already have one under a srw 1-ton. It looks like everything other then the shock mounts are the same?
Old 03-25-2013, 02:30 PM   #4
csdineley
csdineley's Avatar
What I was hoping was that I could unbolt the leaf springs and brake lines. And move the unit over and bolt it back in my truck. As I said the shock mounts are different. For this I was thinking of drilling out the rivets on the upper mounts of the 1-ton, and bolting them on my frame?
Old 03-25-2013, 03:02 PM   #5
Rubble
The oneton springs are longer and the spring hangers sit closer to the frame as well.It would be easier if you do like ghetto suggested & just swap axle...Removing the spring hangers is a bit more work.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 03-25-2013, 06:19 PM   #6
ghettoluxury
If you want to use the one in the 1 ton than you will need to remove the spring hangers and transfer them over or grind the welds off of the spring pads and weld them in the correct spot.
Old 03-25-2013, 06:37 PM   #7
csdineley
csdineley's Avatar
Ok guess I'll keep my 14bsf then.
Old 03-26-2013, 02:19 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Just move the axle pads and shock brackets.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
