SM-420 shift boot
does anyone have a pic of this boot
Re: SM-420 shift boot
ttt
![]() Join Date: Aug 2010
I wanna see it too. Anybody know how close a repop is to the orig?
repop |
Me three. There's one on ebay that has the chevy bowtie on it.
http://www.ebay.com/itm/47-50-53-55-...56b5e8&vxp=mtr There's also this style without the logo and a different top design. http://www.ebay.com/itm/47-49-50-52-...70915182056%26
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
i like to see one to, it has to be a 1966 chevy truck 4 speed with the reverse switch on the lower shifter arm.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
From what I've looked at on this subject. The four speed shifter never came with a boot. They had a foam doughnut between the Transmission Casing and High Hump floor pan.
The Transfer Case Control Lever had a simple flat rubber disk with a slit with a few relief cuts to each side of the slit where the Lever was in one of the positions. ![]()
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-25-2013 at 04:23 PM. Reason: added photo |
none of those boots are original
#9 | |
Found this in the Factory Assembly Manual
there ya go
#13 |
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#14 |
( D-D ) is not the same as pickup in the parts book.
#15 |
AEROTRUK63, i bought one of those NOS shifter boots on ebay, it does not fit the 66 with reverse switch attached to the shifter arm.
#16 |
#17 |
The Assembly Manual says it is for "cowls only".
#18 |
my dad bought a new 66 c20 2wd with the 4sp and it had no shifter boot.
1961 chevy K10 my build is------------61K10 build |
#19 |
My 60 k-20 had 1 on it when i bought it
#20 |
our trucks might have come with them on, but i never seen a picture of the boot with the reverse light switch on the gear shifter.
#21 |
![]() Join Date: Aug 2008
I hate to digress but I don't see why anyone would use on of those reverse light switches that attaches to the upper part of the shifter. It is a pretty straight forward modification to drill and tap the back left corner of the transmission cover, right above the reverse shift rail, and install a standard switch in there. it would make for a much cleaner installation, in my opinion, unless you are going for the 100% original type rebuild.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#22 |
![]() ![]() Join Date: Apr 2012
From 1960-1966 on the SM-420 trans they did not have a boot on the interior of the truck. They used a seal that sat around the shifter on top of the transmission. You then installed the floor over the seal and this is what kept air/exhaust out of the cab. All of those boots on EBay are simply something that was made to solve a problem and make things "look" nice for these transmissions. None of my 4x4 trucks have boots. Although my 61 4x4 Panel has the short 2358354 boot still on it. Heres some pictures of the correct under floor shifter seal. Also, from 1960-1962 the seal was the same as pictured but it was shorter 1-13/32 3766203 and 63-66 was 2-21/32 3766204.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#23 | |
#24 |
60-66 have a pic of the transfercase shift boot
#25 |
I find this strange that no boot was provided, yet it explains why no boot was found in my '65 Suburban. Everything else in that truck is original, untouched, intact, complete, etc.
Also, back when I first got it, I don't think it had seen much use for quite some time. Then after driving it around awhile I noticed strange black rubbery goo slowly dripping off the top of the trans onto the driveway. This I am now convinced was the foam seal that had degraded with time and was melting with the heat of the trans. At the time I thought it might be the remains of the missing boot that was melting, but now the foam seal makes more sense. Oh btw Jon (60-66), I am continually impressed with the completeness of your truck and parts obsession. You provide a very valuable service to the serious truck enthusiast. Thanks for that. Last edited by oem4me; 03-28-2013 at 12:23 AM. |
