Old 03-25-2013, 04:02 PM   #1
nickbwilson
rear end gear ????
hey guys i have 85 c10 shortbed with a 5.3 with ms3 cam from texas speed im running a 4l60e trans ive read where i need atleast a 3200 stall with this cam question i have is my truck currently has 207 gears what gears would you guys recommend to run in the rear end with this cam and stall combo thanks
nickbwilson is offline   Reply With Quote
Old 03-25-2013, 06:27 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: rear end gear ????
With a gear ration like that, I'd think you'd want to back down A LOT, unless you plan on building a car to cruise at 80mph. The 3:73, and 4:10 gears are always popular, and since your' running an overdrive trans, either would work for your application.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-26-2013, 08:18 PM   #3
Jon01
Jon01's Avatar
Yup, 3.73-4.10 is ideal.
I'd also get a looser converter - something in the 3600 neighborhood.
Jon01 is offline   Reply With Quote
Old 03-27-2013, 08:52 AM   #4
68Stepbed
68Stepbed's Avatar
With the MS3 and a 3200 stall, alot of guys run at minimum, a 4.10 gear. To really take full advantage of the cam's potential, a 4.30 or 4.56 gear is recommended.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-28-2013, 02:27 AM   #5
BigDan3131
BigDan3131's Avatar
You need to factor in what tire height you have as well.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-28-2013, 03:23 PM   #6
mooseknuckles
mooseknuckles's Avatar
207 gears?
mooseknuckles is offline   Reply With Quote
Old 03-28-2013, 10:16 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
....... or 3.07?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-29-2013, 08:34 PM   #8
kevmac
kevmac's Avatar
I run a ms3 in my5.7/m6 67 Camaro swap. it has 373, should have 410. My 2 cents
kevmac is offline   Reply With Quote
Old 03-29-2013, 11:18 PM   #9
68GMCCustom
what he said. I've got 3.73's in my truck and wish it had the 4.10's my TrailBlazer SS has. The 14 bolt w/disc brakes would be nice too!
Kurt -
Old 03-29-2013, 11:31 PM   #10
mooseknuckles
I had the stock 3:08"s with the 6.0l...that thing would fly!!...a little more sensible now with 3:42's..... 3:73's are too low for me to be driving daily..
