Old 03-25-2013, 04:59 PM   #1
stroker52
wheel back spacing info
now that im changing over the the 5on4 3/4 bolt pattern do to the wheels im getting from weld racing i need some help with back spacing. the truck is doing to be dropped 4/6 big sway bars front and rear with QA1 shocks on all for corners. but im un sure on the back spacing ive done some searching and see most are using 5.5 in the rear and around the same on the front. i have the lip trimmed off the front fenders and welded back up.
i will be running 18's on all 4 corners 8.5 in front and 10's out back..
stroker52 is offline   Reply With Quote
Old 03-25-2013, 05:21 PM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: wheel back spacing info
Where in Texas you located?
I did some looking around most guys typically use a 15x8 and 15x10, so I don't see why an 18 would be any different, what i've read is that most are running 4-4.5" in front and 5" in the back.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 03-25-2013, 05:39 PM   #3
stroker52
im in houston on the east side close to baytown..
the 18's im having to order them so i have to be dead nuts on the BS i just got off the phone with weld racing and they have a paper i have to print out and get out the tape messure lol..
Old 03-25-2013, 06:41 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I would run a 5.25" BS on a 18x8.5 up front and a 5.5" BS on a 18x10 since you have a 73-87 rearend.
15" wheels will only allow a max of 4" BS up front because of their small diameter.
Keith
Convert to disc brakes.
Old 03-26-2013, 12:31 AM   #5
stroker52
how close will the 5.5 BS out back put the wheel to the fender? i dont want the goofy look these trucks have when there dropped with the rears tucked in more then the front.
