Old 03-25-2013, 05:01 PM   #1
jae
Fuel pump recommendation for Carbed LS?
Like the title states, just wondering what you carbed LS guys are using for an external electric fuel pump. I looked briefly at the Edelbrock 1791 pump, just wondering if there are better options out there.
I'll be doing a 5.3L w/ a 650 cfm carb for now.
jae is offline   Reply With Quote
Old 03-25-2013, 06:25 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel pump recommendation for Carbed LS?
Since the fuel demands on a carbed lsx are pretty low, almost any aftermarket low pressure pump should work just fine; I've used Moroso, Edelbrock and Denso pumps in the past on other carb'd projects.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-25-2013, 06:30 PM   #3
jae
Sounds good. I dont want to end up spending more money than i have to, so I'll keep looking and see if I can find something under $200.
Any recommendations on gph ratings?
Old 03-26-2013, 03:22 AM   #4
BigDan3131
BigDan3131's Avatar
Pretty low? I would say low pressure [6 psi without a reg and 12-18+ with one] maybe but when you start building horsepower its just like anything else that is carbed more is better.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-26-2013, 08:42 AM   #5
jae
Yeah, I interpreted his statement to mean low pressure, not just low demand. I don't see why a carbed LS would use any less fuel overall than an FI engine.
Is a 120 gph rated pump overkill for a ~500 hp application, or should I think about going bigger knowing that is my approximate power goal?
Old 03-26-2013, 08:46 AM   #6
68Stepbed
68Stepbed's Avatar
I used a Carter pump. It's internally regulated so no need for a regulator. It was about $80. Due to its design, though, it's hard to find a good place to mount. If I ever change it out, I'll go with the Holley inline billet pump. A bit more expensive, but should mount easier, and be a bit more quiet than the Carter pump.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-26-2013, 10:10 AM   #7
jae
FWIW, I had a vender over on LS1tech suggest the Holley 12-802-1. Looks like it's a 14 psi, 110 gph pump that comes with a regulator. Has anyone had experience with this pump?
Old 03-26-2013, 04:49 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I mean pressure demand vs what is required for the injected swaps.
Old 03-26-2013, 05:29 PM   #9
LEEVON
Moderator
LEEVON's Avatar
This is the way to go, the Carter pump has the edge in reliability.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-27-2013, 08:50 AM   #10
68Stepbed
68Stepbed's Avatar
If you're referring to one of these--> http://www.jegs.com/i/Holley/510/12-801-1/10002/-1 then yes, the Carter is more reliable. That's why I chose the Carter over these. Alot of folks on LS1tech complained about these going out every 8-12 months.
I'm talking about one of these pumps--> http://www.jegs.com/i/Holley/510/12-890/10002/-1
Here's the pump I have.
http://www.jegs.com/webapp/wcs/store...Term=180-p4594
Matt
Old 03-27-2013, 10:16 AM   #11
jae
What's your engine setup? No fueling issues? I don't really have a benchmark so don't know exactly what I should be looking for as far as GPH ratings.
Old 03-27-2013, 12:07 PM   #12
68Stepbed
68Stepbed's Avatar
LS1(5.7L) stock 241 heads, stock bottom end, 232/240 .581/.581 110+2 cam, TSP? dual valvesprings, TSP 7.400" pushrods, Edelbrock Performer RPM dual plane intake, 750 Street HP carb. I'm also running 3/8" fuel line from the tank to just behind the engine, then -6AN to the carb.
So far, no major fuel feeding issues. It does seem to feel sluggish under WOT, but my trans is shifting too early which may be causing part of that. I also may have the floats set low, which can cause that. I removed the sight plugs while tuning a few days ago, and no fuel seeped out.
As for GPH ratings, most pumps will have a description for the intended use of the pump, examples: street use(daily driver), mild performance street, street/strip, and racing.
For a stock or mild cammed 5.3, anywhere between 70-100 gph will be fine. If you decide to turbo/supercharge, or run nitrous, you will need 100+GPH
Matt
Old 03-28-2013, 02:25 AM   #13
BigDan3131
BigDan3131's Avatar
I always build a fuel system as though I were going to make a thousand horsepower, overkill never hurts and doing it once is cheaper in the long run.
Do you want to run a regulator, is one question you need to think about. I would because I prefer having the volume at hand when I mash the pedal to WOT. I'm using a Holley pump that's rated at 160 GPH which will support about 750 HP based on my line sizes. On the other hand my friend has a Holley Blue pump with 1/2" line all the way from tank to dual carbs on a blown 540 making 980HP because that's what his engine builder told him to run. Big pumps will last longer and run cooler with a return line, which I also have.
Old 03-28-2013, 05:09 AM   #14
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I'll be doing a 5.3L w/ a 650 cfm carb for now.[/QUOTE]
Does this mean that you are planning to run fuel injection later? If so, it's cheaper to go that route now if you have serviceable components on your 5.3
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-28-2013, 10:04 AM   #15
jae
No idea what plans are for the future. At one point I had considered buying a short block and building it up with LS1 intake and fueling components, and it's pretty cheap to get the stock LS1 stuff. However, it's hard to beat the look of the carb in an old truck like this (not to mention I've already got the carb and tuning will be much easier). I've toyed with the idea of supercharging or turbos in the future, at which point I think I would want FI, but I'd likely redo 90% of the fuel system for that setup anyway, and it's YEARS in the future if at all. I need to get the truck running soon and think this will be the quickest way.
