Old 03-25-2013, 06:53 PM   #1
mfm3
Active Member
Drive line shop in Sacramento?
Posted in the Southwest region forum, but thinking I can reach more of you here. Thx
http://67-72chevytrucks.com/vboard/s...12#post5970512
mfm3 is offline   Reply With Quote
Old 03-25-2013, 07:57 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Drive line shop in Sacramento?
I believe there's a Driveline Service in W. Sac If my memory is still working.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-26-2013, 01:38 AM   #3
mfm3
Active Member
Yep...they don't wrench, but I should call and ask if they can recommend a shop. Thx
Old 03-26-2013, 08:18 AM   #4
Ol Blue K20
What kind of work you need to have done?
Dale
Old 03-26-2013, 10:53 AM   #5
mfm3
Active Member
Recently purchased a 66 C10 with a 454, TH 400, Gear Vendors OD and a 9" Ford with 3.55 gears. The drive line is stout, but has a harmonic vibration between 65 & 85 MPH. Plus the tranny seal and pinion seals are leaking. All this is out of my wrenching comfort zone. Looking for a shop in the Sacramento area. Thx
Old 03-26-2013, 10:57 AM   #6
Ol Blue K20
Yeah I won't be able to help there, I dont know the shops there. But the drive line balance probably killed the seals. Once you find someone to fix the seals, take the shaft to the place i told ya about it'll be smooth as glass
Dale
Old 03-26-2013, 11:37 AM   #7
mfm3
Active Member
Good advice...thanks.
Old 03-26-2013, 11:53 AM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
Unless you have a driveshaft ballancer it doesn't matter if its within your wrenching comfort zone. We could sell you one for about $30k, its a lot cheaper to have a driveline shop check out and ballance your shaft. Hopefully you haven't ruiled the tailshaft bushing or tranny yoke yet.
Id help but shipping to missouri would cost as much as the ballance. We have a couple of shops in california but without looking at a map I couldn't tell you how close they are to sacremento, pretty sure nobody speaks english at either one. Lol
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-26-2013, 12:04 PM   #9
kwmech
Sacramento Driveline Service 1-800-332-2800
or if any of you are in the Chico-Oroville area. You can call my son in law @
Driveline of Paradise 530-877-1441
Old 03-26-2013, 12:23 PM   #10
mfm3
Active Member
Tail shaft bushing, tranny yoke, drives shaft balance, etc...all reasons I need a pro.
Yeah...Chico is a little far. Thanks for the Driveline Service info.
