Truck won't start????
I have a 71 C10 350 truck with carb and hei. I went out this afternoon to start the truck and it wouldn't start. It turns over but does not start. I have a hi torque starter on it. While having someone turn the key I went and looked under the truck. The starter is turning the flywheel so I'm not sure if it's the starter or not.
Over the past month the truck has been starting great with no issues but I have been noticing that if I shut the truck off, it doesn't start as easy if I try to start it within 5 mins or so of shuting it off. Anybody have any suggestions what my issue might be? |
Re: Truck won't start????
pull the air cleaner and check your getting fuel. If getting fuel, pull the cylinder 1 plug wire and use a spare plug to check for spark. If getting spark to the plug.....I would recommend checking all plugs to see that you are not fouled out on at least 5 of them. Sometimes if they are getting hard to start after running, can be a case of flooding, which could be from fouled plugs not burning off fuel properly. Start there. Wont be starter if you can see flywheel turning.
Active Member
![]() Join Date: Jul 2007
Yeah, if it's turning your starter is not the problem. As buckskin mentioned, check the spark plug and if you don't see a spark it could be HEI module.
Also, if the engine has a quadrajet you could have leaking well plugs. If you smell fuel and/or dark gray or black smoke comes out of the exhaust when first starting it and you can't see where it's leaking from, you will have to take the carb off and check for that problem.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#4 | |
How do I prevent the plugs from fouling? |
![]() Join Date: Jan 2001
From what you're describing, I think you need to rebuild your carb. If the smell of gas is strong at the exhaust, that's a good indication.
Next time you have a hard time starting it, pull the air cleaner cover and see if the choke is open. If it's not, your choke coil may be bad or it may just be disconnected. |
#6 | |
Cluster King
![]() Join Date: Nov 2012
First of all, make sure you have spark. If yes, try this:
Use a screw driver or something to hold the chock completely open, then hold the accelerator pedal all the way to the floor and try to start the engine. It sounds like it is flooded and your choke may be adjusted incorrectly or you have a bad chock pull off. it may take a minute to get going but do not pump or let the accelerator go back to idle. The engine needs air. |
![]() Join Date: Sep 2011
Sometimes a sunk float will cause what you are describing. It starts easier after sitting a while or first thing in the morning. I would lean toward some kind of carb issue.
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
#9 | |
Fouled plugs generally will be black and almost kinda a charcoal residue on them. The entire plug will be black. Good thing is that plugs are dirt cheap for stock 350's. You could see if someone would rebuilt your carb, I personally would just go buy a Holley Street Avenger and run it right off the shelf. |
i would pull spark plugs and clean and gap them // then i would go to the distributor and clean the points and set the dweel
The plugs are definitely fouled. I pulled them this morning. Is there anything I can do about this other than having someone tune my carb? Meanwhile I'm getting some plugs today.
i'd spray the spark plugs with wd40 and use a wirebrush clean them up and gap them
#13 |
Junior Member
Your chock may not be opening after the initial start. We don't even run chokes on our Chevy trucks, of course we don't drive them when it gets real cold outside.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
#14 |
How hard is it to adjust the A/F mixture? How is it done?
#15 |
is your sparkplug fouling gas or oil related// u should maybe figure that out
rebuilding and sticking to turning screws and dials on a carb will not help oil consumption issues
#16 |
Replaced the plugs and the truck fired right up. Guess I need to adjust my air / fuel mixture. The plugs had carbon build up on them.
