Floor Pan Replacement
I want to enjoy my new project for the summer and keep saving for a rebuild. Replacing the gas tank and pulled up the floor mats. I want to replace a small section of floor pan on the driver side. Anyone have any opinions on the quality of LMC or Eckler's floor pans? I'm open to any opinions or suggestions. Thanks.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
Re: Floor Pan Replacement
I got mine from Classic Parts, and they were decent. Passenger side needed some persuasion, but drivers side fit well.
I got other panels from them as well and some from Early Classic Enterprises. Almost everything I have ordered from LMC has been crap. And I despise the packing peanuts they use. I've ordered from Eckler's, but not repair panels.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
I am a Referee of life.
Any of the BB vendors should be able to hook you up.Most sell only the best quality available and have installed one or two so they can probably give you good CS also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
LMC floor pans look like the ocean!
Who is a BB Vendor? New to the forums and unsure what you meant. I will figure it out eventually this board rocks.
I tried Goodmark replacement pannels and did not have much luck with the floor panels. The bends did not mach the factory ones and after several wasted hours of cutting and reshaping we decided to cut the floor out of a wrecked cab. Hope this helps.
