Old 03-25-2013, 11:22 PM   #1
79er
350 build
i pulled the 350 out of my 80 1 ton silverado. i want to build it up a little bit headers intake heads cam timeing chain and gear. i have a holley 600 cfm that needs to be rebuilt. the truck has a 400 turbo trans in it. i want to spend 1500 to 2000. any ideas on what i could do or what you guys have liked with your builds.
79er is offline   Reply With Quote
Old 03-25-2013, 11:53 PM   #2
Ziegelsteinfaust
Re: 350 build
Vortec heads from Summit, or if your adventurous get a Vortec 350 as your starter. It comes stock with the heads, and a roller cam. So a good balance job, and a decent cam it would be a power house for DD or work. Plus the 1 piece seal is better.
If I do a sbc in my truck a Vortec or the newish LT1 will by my choices.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-26-2013, 12:49 AM   #3
bilfman
bilfman's Avatar
Re: 350 build
Heads will always be the single best improvement.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-26-2013, 10:24 AM   #4
chrly1492
Re: 350 build
you mention adding items to the top-end, are you also planning to go through the bottom as well? Can't go wrong with Vortec heads, but be prepared to spend what you have proposed in your budget. If you plan on running more than 460 lift, look for the heads that have been machined for that, if not stock are still great.
chrly1492 is offline   Reply With Quote
Old 03-26-2013, 02:43 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 350 build
Are you building it or adding performance parts to the short block
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
