03-26-2013, 12:46 AM | #1 |
How do i get "the right sound" from a 292?
I'm installing my 292 very soon, time to think about exhaust notes........
I DO NOT want this to sound like grandpa's truck, but I don't want open headers either. I'm thinking I'd eventually like to do a split header and true duals, but for now I'm leaving the engine basically stock with single exhaust. What pipe diameter and muffler combinations would you recommend? Links to videos with decent audio would be great So guys, what sounds good? Posted via Mobile Device |
03-26-2013, 01:06 AM | #2 |
Re: How do i get "the right sound" from a 292?
Porter mufflers.
But I doubt you'll be happy til you flip for true split exhaust manifolds and 2-1/2" pipes from one end to the other. |
03-26-2013, 01:56 AM | #3 |
2 1/2 to a large 3 chamber magna flow and 2 1/2 out.
www.12bolt.com click the video link and listen to the malibu wagon 2nd vid Posted via Mobile Device |
03-26-2013, 11:33 AM | #4 |
Porters or Smitties if you have a traditional style truck and what ever you like if you have one decked out with more street roddy stuff.
I'm going with the same cast iron headers that Newfisher has on his but running Porters because I like the sound of the old style glasspacks on sixes better than the turbos. Click on the little 63 Biscayne with the 292 next to the copper F1 pickup. Video is too short though. http://www.portermufflers.com/porter-videos.html That is why sweet sound trumps loud.
03-26-2013, 11:57 AM | #5 |
Thanks for the videos guys, the Porter's sound great, but I think Dan is right, I probably won't be completely happy with it till I get the split headers on it.
Just finished disassembling the engine last night, everything looks good inside. New bearings, rings and gaskets should have it back together by the weekend. The truck it came out of sat in the woods for almost 15 years, but everything seems to be fine internally, so hopefully I can back the truck out of the shop under its own power in the next few weeks! Posted via Mobile Device |
03-26-2013, 01:27 PM | #6 |
I'm going fenton headers and the Dynomax ultraflow. It is basically an x-pipe inside a muffler housing. Very low back pressure + exhaust scavenging. It will be a while before I have any "sounds" to share though.
03-26-2013, 01:29 PM | #7 |
03-26-2013, 08:30 PM | #8 |
I have split headers and true duals on my 292 and it sounds like a small block at idle. It's also bored .030 over. I'll see if I can get a video this weekend.
03-26-2013, 08:37 PM | #9 |
Please do.
03-27-2013, 07:27 PM | #10 |
Would love to hear this. I am running a 292 with split exhaust in mine and am looking for that type of sound.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
03-27-2013, 09:03 PM | #11 | |
03-27-2013, 09:07 PM | #12 |
Yes I would also like to hear it
03-27-2013, 09:11 PM | #13 |
Actually the sound should be what you like. The sound I like is that similar to what my buddies had with their Chevy sixes with split manifolds and duals or a set of Fenton Cast headers and duals in the early 60's when I could hear Ray Rojas cruise by my house in the evening in his lime fire green 51 Chevy hardtop and know it was him. Every six with duals in town had a distinctive set of pipes on it and you knew who was going by by his pipes and didn't even have to look out the window or out from under the car you were working on in the garage.
That may not even be close to the sound you want now though. Older guys usually like the glass packs while younger guys seem to go for the sound of a set of turbos.
03-27-2013, 11:14 PM | #14 | |
03-28-2013, 12:10 AM | #15 |
Hey Redneck Rodder,
I have NO connection to this ad whatsoever. I just happened on it and remembered your thread. http://losangeles.craigslist.org/sgv...707090636.html Shipping charges would probably be prohibitive, but I thought you MIGHT be interested. Just FYI, Dan |
03-31-2013, 02:35 PM | #16 |
I took a video as promised, now to figure out how to get it on here..
04-01-2013, 07:42 PM | #17 |
04-02-2013, 04:43 PM | #18 |
Do I have to upload it to YouTube then post a link to it?
04-02-2013, 07:06 PM | #19 |
That would work. just copy the Youtube link and paste it here
04-29-2013, 12:34 AM | #20 |
04-29-2013, 01:06 AM | #21 | |
04-29-2013, 09:44 AM | #22 | |
04-29-2013, 12:37 PM | #23 | |
04-29-2013, 05:38 PM | #24 |
Sounds awesome!!!!!!!!!!!!!!!!!!! I'm curious though,........Why are you not using the proper water pump for the 292? It looks as if you have a 250 pump without the coolant bypass.
04-29-2013, 11:00 PM | #25 | |
And thanks for the responses guys. That was a cold start so the idle will usually settle down after a while and get a little mild cam idle sound going to it. Posted via Mobile Device |
