Old 03-26-2013, 09:16 AM   #1
75chev4x4
75chev4x4's Avatar
is this block unusable???
Hey guys found a 400 sbc block that I wanted to possible pick up cheqp and put away to build sometime when I have the cash. I know these are getting harder to find. Found this one but looks to have had a rod break loose and messed up the bottom end. Does it look usuable still or is it just a boat anchor? This is not mine but I was thinking about buying it if u guys think its still good, thanks.
http://portland.craigslist.org/clc/pts/3670768376.html
75chev4x4 is offline   Reply With Quote
Old 03-26-2013, 09:19 AM   #2
77c10
77c10's Avatar
Re: is this block unusable???
I would steer clear of it but that's just me. Looks like it would need to be bored and sleeved. May also need a new crankshaft.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 03-26-2013, 09:21 AM   #3
79Betty
79Betty's Avatar
Here at jasper we'd sleeve it and run it. I think you'd be ok.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 03-26-2013, 09:24 AM   #4
stroker52
If there is signs of a rod coming in contact with the main webbing of the block i would pass.. 400 4bolt main blocks are kind weak to start with so pass this one up..
Also if your dead set on a 400 find a 2 bolt main block and have splayed main caps installed this makes the block stronger do to not having the outer main bolts drilled into the webbing of the block..
stroker52 is offline   Reply With Quote
Old 03-26-2013, 09:32 AM   #5
75chev4x4
75chev4x4's Avatar
Ok thanks guys, I have a perfectly good 350 in my truck but always wanted a 400, ill keep looking though, thank you.
Old 03-26-2013, 09:35 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
thats bad, what else is wrong?
repairs like that can add up quick
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-26-2013, 09:12 PM   #7
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Not a 100 dollar block. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 03-26-2013, 09:32 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
I would use it. Not even sleave it. I would send it in to have the block x rated and magna fluxes for cracks (do this with all blocks any way) which you'd still gambling with anything else. And the sonic check. Thaw part that makes this worth the effort is that its virgin bore as the add says. Take it to a shop that can torque plate hone it and give her a go.
The add shows a two bolt main. So just relieve any sharp angles and such to get rid of stress risers at the cylinder base.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-26-2013, 09:35 PM   #9
meatwagon83
meatwagon83's Avatar
that block is junk!
and there is a reason i wont buy a jasper engine
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 03-26-2013, 09:36 PM   #10
75chev4x4
75chev4x4's Avatar
Yea I was gonna offer 50 if u guys thought it would be ok but I dont wanna get stuck with it, ended up stuck with a 78 f350 that way haha.
Old 03-26-2013, 09:40 PM   #11
INSIDIOUS '86
That area gets clearances the same way for a stroker crank nothing to fret bout
Old 03-26-2013, 09:44 PM   #12
75chev4x4
75chev4x4's Avatar
Yea sems like a lot is gone though, love to have a 400 sometime though.
Old 03-26-2013, 09:46 PM   #13
meatwagon83
but the material isnt removed the way that was, you might clearance you block with a big hammer but i sure dont, that block is junk!
Old 03-26-2013, 10:22 PM   #14
Daveyboy1983
You could sleeve that block... but whats the point?? After all that time and money in machining, sleeving, and buying new this and that you could have saved your wallet and just found a cleaner builder motor...
Start with a good foundation or all your work and money will be in vain!
Daveyboy1983 is offline   Reply With Quote
Old 03-26-2013, 10:28 PM   #15
INSIDIOUS '86
True yes but the surfaces are not thrust surfaces or such either. I think it could be a great 500+hp 406
Old 03-27-2013, 01:01 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Shp dart if your serious about making power.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-27-2013, 02:28 AM   #17
INSIDIOUS '86
Amen to that. If your playing with a 400 you better go for power. Otherwise go 383
Old 03-27-2013, 07:41 AM   #18
BigBlocksRule
Pass.
400 blocks are a crap shoot anyway, no reason to start with one that's been blown up. When rods break and the crank spins what's left, it tears hell out of pretty much everything. I saw an aluminum 540 that had a wrist pin boss break out of a piston. The swinging crank (at 7500rpm's) literally sawed that block in half.
This one has broken at least two rods - 3/4 and 4/5. Nobody knows how much damage is there that you can't see and may not be found before a build.
BigBlocksRule is offline   Reply With Quote
Old 03-27-2013, 04:57 PM   #19
rusty76
rusty76's Avatar
Blocks like this are usually free around here 400 or not. My buddy got a 350 block years ago at a swapmeet for free. We knew it had a crack but he had an idea. Unless you can fix it yourself pass on it. There's still a few out there.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-27-2013, 09:09 PM   #20
russgt
russgt's Avatar
If it passed a mag and x-ray test, I would have no issues running it without sleeves. Splayed caps are a good idea, but if you are looking for a reliable, long lasting 600 hp/7000 rpm engine, then you should be using an aftermarket block anyways.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 03-27-2013, 09:25 PM   #21
Redcap
Boat anchor.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 03-27-2013, 11:17 PM   #22
kalbert
Yup... Boat anchor IMO. Generally speaking, if you have to ask, you already know the answer For the money to build that block into anything you could put a stroker rotating assembly in your 350 and have almost a 400cid. Bare blocks aren't the expensive part, it's all the machine work and the rotating parts to make the block into anything that gets you. Might as well start with one that hasn't seen that kind of action if you can.
kalbert is offline   Reply With Quote
Old 03-27-2013, 11:25 PM   #23
mrolds88
I would pass on it. While the area is the same as the clearanced area for a stroker crank, the material wasn't removed in the same manner. As the material was punched out with not a lot of precision. Plus under the residue that is still left on the block can easily hide other cracks that were caused by the same incident.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-28-2013, 12:49 AM   #24
LynnJr
A die grinder with a carbide burr will make short work out of the bottom of those cylinders.If it mags okay you would be all set.
Most of the 350 4 bolt mains you find are already cracked so nothing wrong with this one if it isn't cracked or into water.
If it needs hard-blok your another $80 into it.
LynnJr is offline   Reply With Quote
Old 03-28-2013, 04:14 AM   #25
CSGAS
optomistic ah-so
CSGAS's Avatar
It looks like that block has already been sleeved before, and either the bottoms of the sleeves were not clearanced, or the machinist pressed them in further than he wanted too and didn't cut enough off the top (or didn't cut the top at all and pressed them in til they were flush).
That would explain why he had rod problems.
It's really not the pictured block that's discouraging. New sleeves can be pressed in by someone who will clearance them properly, and so on. Often sleeves are considered preferable in racing because of the things that have improved since the original siamesed walls were machined.
What would bother me though are the things he's not showing, but trying to give you for "added value." That means a lot of bolt-on parts, all the way down to the oil filter adapter, are likely damaged and have to be replaced.There's no reason for the seller to take those parts off just to see if he had a spun bearing. He took them off for some other reason, and any part that's good is a part he plans on keeping.
Let someone else spend their money on this one. Restorers would spend the same amount of money on any engine as this one needs spent on it. Same thing with racers. Both are likely to have a stash of probably half the parts that are not included or unusable. It just isn't a bargain for a street build.
Do you know someone who's turning in an engine that you know is rebuildable, as a core for a standard rebuild? If so just offer him a dollar or two more than the core charge he would get, and save him a trip. You'll get whatever spare parts he doesn't need and be further along in your "spare time" motor than if an unknown block is all you could start with.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
