Old 03-26-2013, 11:59 AM   #1
Jayschevy
750cfm to 670cfm carb
I have a 71 350 C10 that the PO installed a 750cfm Holley carb on it. Would it cause a problem if I took the 750cfm carb off and installed a 670cfm carb on it? Will the smaller carb cause any problems?
Jayschevy is offline   Reply With Quote
Old 03-26-2013, 12:03 PM   #2
vidman
vidman's Avatar
Re: 750cfm to 670cfm carb
You would see a small jump in MPGs. If you are not racing around the track or street it will cause no harm
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-26-2013, 12:05 PM   #3
doubleb's69
doubleb's69's Avatar
A 750 Holley seems to be a little too big for a 350 without the work to justify it especially if it is a double pumper. I run a 600 Holley on a stock 350 and it runs great. Is there any engine mods like a bigger cam or higher compression heads with a bigger intake runner? And what is the intake manifold it will be going on.
Bud
doubleb's69 is offline   Reply With Quote
Old 03-26-2013, 12:22 PM   #4
Jayschevy
The PO did do some mods. I'm only aware of the higher compression heads, HEI and aftermarket intake manafold.
Old 03-26-2013, 01:01 PM   #5
Lattimer
Lattimer's Avatar
The 670 is probably closer to ideal in airflow anyways.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-26-2013, 02:48 PM   #6
69GWC
I have a 670 on my 69 and it works real well , i agree a 750 might be to big for your motor.
69GWC is offline   Reply With Quote
Old 03-26-2013, 04:40 PM   #7
OC 72
OC 72's Avatar
You should be okay with the 670....have had 700's on my SBC before and its too much carb..even it its jetted etc.
OC 72 is offline   Reply With Quote
Old 03-26-2013, 04:43 PM   #8
leddzepp
Moderator
leddzepp's Avatar
750 is too much for your small block. Switch it out.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 03-26-2013, 08:14 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The smaller carb will be fine.It may improve street performance some since the air signal to the secondaries will be better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-26-2013, 09:05 PM   #10
Sicklajoie
The Niner
Sicklajoie's Avatar
Mine originally came with a 750 double pumper which was way too much for my mild 350. I've got a 670 Street Avenger now and it's a lot better.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 03-26-2013, 10:16 PM   #11
70CHEVYBB
70CHEVYBB's Avatar
I may be interested in the 750 if you were going to sell it?
70CHEVYBB is offline   Reply With Quote
Old 03-26-2013, 11:10 PM   #12
Jayschevy
PM sent
