Old 03-26-2013, 12:02 PM   #1
SaltySam
LSD? and no not the drug
i have a 67 with the stock rear end and i wanna put a lsd in it. how do i go about doing that?
SaltySam is offline   Reply With Quote
Old 03-26-2013, 12:42 PM   #2
'72customdeluxe
Re: LSD? and no not the drug
You could do a "lunch box" locker. Installs in the stock open carrier. I have a detroit ez locker I need to install. Way less smooth than an lsd though.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 03-26-2013, 02:00 PM   #3
Longhorn 70
Longhorn 70's Avatar
Least Significant Digit??
No not that one.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-26-2013, 02:28 PM   #4
DesertCat
DesertCat's Avatar
No not that one.
... and quit thinking so Octal!
(that ought to create some head scratchin')
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 03-26-2013, 02:30 PM   #5
DesertCat
DesertCat's Avatar
12 bolt? What gear?
An Eaton Posi is a slam dunk but you need the right one.
Old 03-26-2013, 02:47 PM   #6
Longhorn 70
This may help also.................
http://67-72chevytrucks.com/vboard/s...d.php?t=536119
Old 03-26-2013, 04:21 PM   #7
cheyenne shortstep
cheyenne shortstep's Avatar
What the heck is an LSD?
cheyenne shortstep is offline   Reply With Quote
Old 03-26-2013, 04:24 PM   #8
BarryB
BarryB's Avatar
Limited slip differential
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 03-27-2013, 08:42 AM   #9
68Stepbed
68Stepbed's Avatar
My vote is for an Eaton if you have a 12 bolt. If your running anything without c-clips, like a Ford 9", then a Detroit Tru-Trac is a good setup.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
