03-26-2013, 01:05 PM | #1 |
Water temp gauge sending unit?
I'm installing an LS3 motor and wanting to use my factory dash cluster gauges on my 69 c10. I know I have to use and adapter for the head threads, but will any sending unit work with my gauges or is there a special sending unit for this application?
Anyone,anyone?
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803 Dennis H 1969 Chevy C10, SWB, LS3,6.2L engine 1969 Chevy Chevelle SS,BBC, Convertible |
03-26-2013, 08:49 PM | #2 |
Re: Water temp gauge sending unit?
I saw where someone drilled and tapped the flat spot on a 5.3 ls water pump and used a stock temp sensor.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
03-27-2013, 06:19 AM | #3 |
Watch out for your cornhole !
Over on LS1 tech, guys are just drilling and tapping the sending unit hole in the head for the larger old style sending unit.
