Old 03-26-2013, 01:22 PM   #1
phil2013
1969 Chevy C20 396
New to forum. I recently bought a very clean 1969 Pickup. It is a two wheel drive and has a very clean body with no rust.
the timing seems to slip, seems to the retarded side, causing it to lose power. I'm looking to do some easy horsepower fixes for under 800.00. any one have suggestions to wake up this old 396, I know it has much more power than it is presently doing, it's kind of a dog. electronic ignition and carb work?, if so, what kind works best. I just use it as a daily driver and may tow once in a while with it. (small boat)
It presently has a small holley carb on it. (i actually prefer the old quadra jets) (high school days) Also what kind of carbs go best on these? I had a 396 in high school and it was much more a power keg than this truck.
anyone know some good mechanics in salt lake area?
I will post pics.
phil2013 is offline   Reply With Quote
Old 03-26-2013, 01:58 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: 1969 Chevy C20 396
first welcome... Those are cool old trucks. The 396 that year was peppy to say the least.
second, what do yo mean the timing seems to slip? Is the distributor moving? Does it still use points?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-26-2013, 02:07 PM   #3
phil2013
yes, it has stock dist and has points. the bolt is tight on the dist but seems to slip? prev owner said it has an rv cam, but i can't confirm that
I was told this orig came with a 350 but they had a mechanic do a 396 conversion in the mid eighties, (have the receipt) from the prev owner.
Old 03-26-2013, 02:12 PM   #4
truckster
truckster's Avatar
Welcome to the board from a fellow Utahn.
An HEI and a good rebuilt Quadrajet would help wake that motor up.
truckster is offline   Reply With Quote
Old 03-26-2013, 02:15 PM   #5
Longhorn 70
If the distributor slips, that could just be it has a wrong hold down on it or the bolt isn't really tight. it could be a few things. I'd mark the distributor positon, pull the hold down off and check bolt, hold down and block to make sure they are all like they should be.
I have also seen caps that have the notch smoothed or broken off still work. They don't lock onto the distributor like they should. Check that.
With points when the rubbing block starts to wear, it does retard timing and increase dwell also. You may want to look at that when you pull the cap to look at the notch.
Old 03-26-2013, 02:20 PM   #6
phil2013
I was told the quadrajets at auto zone are a pos. where can i get a good one? and what kind of hei do you recommend?
thanks
Old 03-26-2013, 02:21 PM   #7
phil2013
I appreciate that, i will check that. thanks!
Old 03-26-2013, 02:43 PM   #8
69GWC
Stick a HEI in it some new plugs and some good wires and maybe a new Street Avenger Holley carb, maybe a good aluminum intake.
69GWC is offline   Reply With Quote
Old 03-26-2013, 03:06 PM   #9
yuccales
yuccales's Avatar
I'd check that timing, dwell, vacuum. Check the choke pull-off to make sure you are not running around on just the primaries, check for burned plug wires. BTW, welcome to the forum.
yuccales is offline   Reply With Quote
Old 03-26-2013, 03:24 PM   #10
truckster
truckster's Avatar
thanks
Guaranteed Carburetors in Florida seems to have a really good price on them. If you have any mechanical inclination and think you might want to tackle rebuilding a Quadrajet yourself, there's an excellent book by Cliff Ruggles available. His website is http://www.cliffshighperformance.com/ I got my current Quadrajet off of a 1980 Cadillac at a pick-n-pull yard, but it's kind of hard to find them in one piece.
I run a stock HEI; I think I got it from a 1978 Chevy or GMC truck. It works great. You'll need to upgrade your wires, and make sure you have 12 volts to the HEI; the stock distributor uses a resistor wire to get 6 volts.
Old 03-26-2013, 06:38 PM   #11
ole dollor
ole dollor's Avatar
welcome to the forum from Texas...what everyone else has said is a good place to start, also if the dist. shaft is tight it could make the dist. slip around. make sure it spins free..
ole dollor is offline   Reply With Quote
Old 03-26-2013, 06:55 PM   #12
71veronica
71veronica's Avatar
first off welcome to the best porn site. We love pics.
71veronica is offline   Reply With Quote
Old 03-26-2013, 07:49 PM   #13
phil2013
thanks for the welcomes! would love to load some pics of my new ride. had one of these in high school!
so is that correct i can not load a pic from my pictures on my pc? where do you guys store your pics online?
Old 03-26-2013, 07:49 PM   #14
RANDAL
RANDAL's Avatar
Welcome from Utah
RANDAL is offline   Reply With Quote
Old 03-26-2013, 08:40 PM   #15
69GWC
Www.photobucket.com. is a good place.
Old 03-26-2013, 10:44 PM   #16
phil2013
heres my baby
Old 03-26-2013, 10:48 PM   #17
phil2013
http://i1310.photobucket.com/albums/...psccf9f697.jpg
Old 03-26-2013, 10:49 PM   #18
truckster
truckster's Avatar
Sure you can. Just use the "Manage Attachments" option below the text box.
Old 03-27-2013, 01:12 AM   #19
71veronica
71veronica's Avatar
very clean how much did you pay? few upgrades i would do is aluminium intake, headers, and an edelbrock carb. thats just me though
Old 03-27-2013, 01:24 AM   #20
Heavy Evy
born to lose
Heavy Evy's Avatar
I saw that rig on ksl. Nice buy! I'm jealous of that big block! I will have one someday.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 03-27-2013, 03:06 AM   #21
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
When you found your truck for sale was it parked right near Interstate 15 not to far South of Salt Lake City ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-27-2013, 09:28 AM   #22
phil2013
i paid 4500.
probably get the intake and headers later. will get the hei and carb redone for now
Old 03-27-2013, 09:29 AM   #23
phil2013
nope, i snagged it out of washington state, which explains no rust
Old 03-27-2013, 05:44 PM   #24
Sicklajoie
The Niner
Sicklajoie's Avatar
Hey that's a slick looking ride! Congrats!
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
