Old 03-26-2013, 04:40 PM   #1
~Whitey~
~Whitey~'s Avatar
aftermarket heat only
Hey all. I'm a the point where I need to make the decision to smooth my firewall or keep it stock and move on.
I'm looking for ideas for after market heat or mods to my existing heat that will enable me to use my stock heater controls and smooth out the firewall.
I have a non AC cab.
any suggestions? tia
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 03-26-2013, 06:15 PM   #2
ole dollor
ole dollor's Avatar
Re: aftermarket heat only
unless you are going to build a show truck i would just leave it like it is...stock heater works good...
ole dollor is offline   Reply With Quote
Old 03-26-2013, 07:58 PM   #3
~Whitey~
~Whitey~'s Avatar
Not a show truck but a daily driver I can be proud of and show off. I just wanted to clean up the engine bay some. I'm not set on shaving the heater box but if there's a mod or aftermarket heater that is reasonably priced and allow me to do that to clean things up, I'd go for it.
Jimmy
.69SWB Build.
Old 03-26-2013, 08:04 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The only heat only option I can think of.would be a bus type heater mounted under the dash with some ducts to defrost.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-26-2013, 08:14 PM   #5
ERASER5
ERASER5's Avatar
Heater only with no outside air? Prepare for fogged windows or cold legs from the vent door.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-26-2013, 11:40 PM   #6
~Whitey~
~Whitey~'s Avatar
Are there no kits that have remedied the fogging? Do all the high dollar AC/heat units have that drawback?
Jimmy
.69SWB Build.
Old 03-26-2013, 11:47 PM   #7
67c10rustbuket
67c10rustbuket's Avatar
Lots of aftermarket options. Check these out.
http://www.summitracing.com/search/part-type/heaters
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 03-27-2013, 01:18 AM   #8
2002yanks
i have this one http://www.summitracing.com/parts/vta-506101/overview/ really nice unit. i have to wire it up still, but it will defrost the windows. i shaved the firewall and only have he 2 hoses coming through the firewall. the panel it comes with is plastic so i mad a new one out of alum.
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018
2002yanks is offline   Reply With Quote
Old 03-27-2013, 09:31 AM   #9
~Whitey~
~Whitey~'s Avatar
Thanks for the links. There are a lot of options I see, but they all would be using the cab air instead of outside air. Any reason why you wouldn't be able to fab an intake for the motors and pipe it out?
@2002yanks - are you going to be able to wire it to your stock controls?
I really want to keep my stock controls, yet I really want a shaved firewall. If it comes down to it... I'd keep it stock rather than sacrifice the stock heater controls. :-/
Jimmy
.69SWB Build.
Old 03-29-2013, 11:42 PM   #10
2002yanks
i dont think you could use stock(atleast on mine). if you look in my build you can see i made a plate to go into the stock location for the new switches.
Old 03-29-2013, 11:54 PM   #11
bigbadchev72
People know me
bigbadchev72's Avatar
I have one of the Summit ones in my Blazer, It puts out some serious heat and i have it piped into the factory defrost and blows onto the floor as well. I am sure you can leave the factory controls there and just have the stock fan speed switch control the summit heater, the divertor cables will not work though
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 03-30-2013, 12:04 PM   #12
bugmasta
bugmasta's Avatar
Get a vintage air kit
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 03-30-2013, 01:15 PM   #13
~Whitey~
~Whitey~'s Avatar
thanks for the replies guys; really appreciate it. I'm kind of leaning to just keeping the stock heat for now. Can always pull the front clip later and smooth the firewall then when I do have the budget for the full blown AC and heat kit.
Jimmy
.69SWB Build.
