Old 03-26-2013, 04:42 PM   #1
btstrohfus
86 3/4 body lift and fan question.
Im in installing a 2" body lift on my 86, and was wondering what my options were for the fan and radiator shroud. im wondering if an electric fan is needed, or if there is a way to lower or cut the shroud to allow for the body lift. thanks
btstrohfus is offline   Reply With Quote
Old 03-26-2013, 05:25 PM   #2
muddnutz
muddnutz's Avatar
Re: 86 3/4 body lift and fan question.
I've always cut the shroud. If you don't want to do that just remove it and go electric. It's up to you on how much you want to put into it
1986 K-10 "ole blue"
muddnutz is offline   Reply With Quote
Old 03-26-2013, 07:20 PM   #3
bohmankid
bohmankid's Avatar
You sound like you already have it partly figured out. either go electric (expensive way) or customize the shroud.
With e fans, make sure you get a large enough cfm to cool your size motor and wire it correctly with large gage wires and relays.
I have no suggestions on lowering the shroud. good luck.
bohmankid is offline   Reply With Quote
Old 03-26-2013, 09:57 PM   #4
Mr. 250r
Mr. 250r's Avatar
cut it thats how i've done....... all my trucks lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 03-26-2013, 11:00 PM   #5
btstrohfus
now if you end up cutting the shroud down, will you need to fill up the gap on the top to keep the airflow sealed up? and one of my friends mentioned something about moving the shroud down, or something like that.
Old 03-28-2013, 06:58 PM   #6
Mr. 250r
Mr. 250r's Avatar
never filled the gap and never will but thats just the way i did it
2003 1500 Silverado
