03-26-2013, 05:29 PM | #1 |
dim only..
Only have dim lights, no brights... replaced the dimmer switch and same thing. Now im assuming bulbs are good, would the headlight switch keep the brights from coming on?
Posted via Mobile Device |
03-26-2013, 05:57 PM | #2 |
Re: dim only..
If it were me I'd replace the bulbs they may be burned out on bright.If not you can always take'm back..I want to say that this happened to me yrs ago...
1964 BBC 402 4x4 |
03-26-2013, 06:04 PM | #3 |
Re: dim only..
Randy may be right. the bulbs may be bad, also check the wiring at the dimmer switch, see if its burnt , maybe a bad connection, might also use a test light to check for fire at the high beam part of the head light, might save a trip to the parts store...
03-26-2013, 06:24 PM | #4 |
Proprietor of Dale's Corner
Re: dim only..
Test light and an OHM meter you can ohm test the bulbs and check for 12v at the switch and then the bulb
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-26-2013, 08:11 PM | #5 |
I am a Referee of life.
Re: dim only..
Chevy or GMC?Sounds like bulbs may be bad but you may have gotten a bad dimmer switch.It's been know to happen.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-26-2013, 09:03 PM | #6 |
Re: dim only..
Chevy
03-26-2013, 10:06 PM | #7 |
Re: dim only..
Had a similar situation years ago on my '71 4x4 shortly after I bought it and after replacing the dimmer switch found the wires were badly corroded going into the switch. The plastic connector was de-formed from a short apparently before I bought the truck. A trip to the salvage yard with a pair of wire cutters gave me a new connector, problem solved. Been good to go since then.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
03-26-2013, 10:07 PM | #8 |
Re: dim only..
03-27-2013, 07:39 AM | #9 |
Re: dim only..
We had the same problem on a '70 GMC a while back. The headlights were very dim and yellow. They also only worked on low beam, no high beams.
Good advice from the guys above. We replaced the the dimmer switch, but nothing changed. We installed new sealed beams and tested the headlight wiring. Still no change. Then we removed the black ground wires from the headlight harness and cleaned the grounds. The lights were much brighter, but still no high beams. We replaced the headlight switch and presto! The headlights were back to normal and we now have high beams. I hope this helps. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
03-27-2013, 01:02 PM | #10 |
Re: dim only..
Thanks everyone. Cant wait to get off work so i can start on it.
03-27-2013, 01:17 PM | #11 |
Re: dim only..
i would check the voltage with my meter on the connector where it is connected to the headlamps
03-27-2013, 08:50 PM | #12 |
Re: dim only..
Simply unplugged and replugged and we had both! Now is there a bulb thats for the indicator ? And im guessing ill have to drop the column to remove the cluster?
