Old 03-26-2013, 05:41 PM   #1
Rusty dusty
6 cyl to V8 swap...
Hey guys, I'm new to this forum, having just acquired a 1960 c20. I have done some searching and can't seem to find a thread describing swapping out a 6 banger for a v8! I am sure there is one, just haven't found it yet. I would be interested in where I can find motor mounts etc. The truck currently has a 6 with a 3- speed column shift. I have a '66 327 out of a wrecked 'Vette that has been in a couple of hot rods I built in the past. I also have a th350 with a B+M shift kit. It would be easier to adapt the V8 to the 3-speed but don't know what is involved. (New bell housing?)
Thanks...
Rusty dusty is offline   Reply With Quote
Old 03-27-2013, 12:46 AM   #2
brb90zc
Re: 6 cyl to V8 swap...
Hi and welcome. I did almost the same thing 2 weeks ago I had a I6/ power glide in my 64 and went to a 350/ th350 swap. All I needed was to new rubber motor mounts from Autozone for a 72 with a V8. And a new trans mount from the same truck. Mine were all worn out....All in all I spent under $30 including tax. The I6 has a metal perch that connects to the frame then the rubber mount( that I replaced) and then another metal mount that attaches to the motor. The one that is on the motor needs to come off and the V8 will mount directly to the rubber mount.
Now for the bell housing I think are the th350 should just bolt right to the back of the 327...I would do that prior to installing into truck...and just drop it all in at one time..
Now a word to the wise from the un- knowing... please put the tranny mount on BEFORE you put it in to the truck. That was a 2 hr mistake for me.
Hope this helps I can get u picks tomorrow if u need
Good luck and have fun
brb90zc is offline   Reply With Quote
Old 03-27-2013, 12:50 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum. This thread may prove helpful. It pertains to swapping a small block V8 in place of a V6, but the torsion bar frame/suspension should be the same"
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-27-2013, 08:38 AM   #4
Rusty dusty
Thanks guys, this should prove very helpful!
Old 03-27-2013, 08:52 AM   #5
da_bears_da1
As brb90zc indicated the stock perches do work for mounting a V8. As you can see in the lower left hand side of the picture, you just bolt in the perches and then bolt the mounts to the perches. I have a 350 mounted in my 65 Step Side. Good luck, this is pretty straight forward.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
