Old 03-26-2013, 09:30 PM   #1
olskool68
Better brake pedal for long legged kid!
We've installed discs up front and I purchased a dual master cylinder BUT before I cut open the plastic, is there a better solution to getting my long legged kid to not hit his knees having to move his foot so high to reach the brake pedal? The steering wheel and seat are original.
I've seen pedals for power brakes that mount to the firewall and frame mounts for manual brakes. What's better guys and gals?
Struck down, but not destroyed 2 Cor 4:9
1958 Apache 32
olskool68 is offline   Reply With Quote
Old 03-26-2013, 10:51 PM   #2
nvrdone
Re: Better brake pedal for long legged kid!
I'm long legged too. I'm thinking you are talking about the stock pedal & under floor mounted m/c.
If so, I cut the pad mount off, shortened the shaft bt 2" and re welded it. Works great
nvrdone is offline   Reply With Quote
Old 03-26-2013, 10:54 PM   #3
olskool68
I thought about doing this, of course would be the cheapest way. My only concern would be if I can't get enough travel. It is the stock setup, except it'll be a dual master cylinder. How far are you from the floor board when you apply full pressure?
1958 Apache 32
Old 03-26-2013, 11:48 PM   #4
_Ogre
_Ogre's Avatar
i'm 6'4'' aka the shortest male in my family
i also have gimpy legs. i cut off 3.5'' with an underfloor hydroboost.
a smaller wheel with a tilt column also helps with long legs.
works great
shop air compressor timer
Old 03-27-2013, 12:15 AM   #5
mr48chev
mr48chev's Avatar
What seat have you got in that truck? that may be a high percentage of the problem.
The seat cushion may be wrong for him to fit or the leanback may be too thick for him to sit right in the truck. With some car seats and some of the high end late model truck seats you loose quite a bit of leg room due to the seat taking up so much space. I had a 56 GMC at the house for a long time that had belonged to a family of skinny short guys and one of them had put a Lincoln town car seat in it that looked ok but anyone over 5/6" and 160 lbs couldn't drive the truck comfortably.
The factory floor mounted pedals will only come up as high as the pedal arm lets them originally. Swapping master cylinders won't raise the height of the pedal over what the stock height was. Think about it a bit, it can't physically happen As the bumper on the pedal arm hit the floorboard with the stock mc and it will hit now with the replacement.
My ongoing truck projects:
Old 03-27-2013, 10:29 AM   #6
olskool68
My concern isn't the pedal coming up higher, its how to make it lower while keeping the stock interior. Looks like shaving the arm down may be the answer. Thanks for all the input folks.
1958 Apache 32
Old 03-27-2013, 10:53 AM   #7
Wrenchbender Ret
Ive cut some off of every one that ive had. It makes it more comfortable to drive & looks better as it matches the clutch. If you need that last 1/4 in of master cyl travel you are already in deep stuff.
Wrenchbender Ret is offline   Reply With Quote
Old 03-27-2013, 11:06 AM   #8
_Ogre
_Ogre's Avatar
to add to my post, i also raised the seat 1.5 inches above the stock seat.
i still have a couple inches of pedal with the brake pedal pressed
Old 03-27-2013, 12:59 PM   #9
Coach529
Coach529's Avatar
I have always thought have the pedal lower would ease the transisition between throttle and braking.....
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-27-2013, 02:01 PM   #10
mr48chev
mr48chev's Avatar
I thought your seat looked a bit higher than a stock seat.
The later model seat in my 71 sits a bit higher than the stock seat did and as I am long bodied and short legged it makes my 5'10" standing height look like 6'6" sitting in the truck
Old 03-27-2013, 09:01 PM   #11
olskool68
I believe this is the winner! My kiddo looked like he had plenty of headroom anyway so we had kicked that idea around. Chop the pedal, raise the seat...fine tune from there! Thanks Ogre
1958 Apache 32
Old 03-28-2013, 11:07 PM   #12
_Ogre
_Ogre's Avatar
my son, at 6'7'' (and still not the tallest ogre family member) has an 68 elcamino
he gets in it by putting his leg over the steering column
lot's of headroom in these trucks, raise the seat
i've always had a task force truck since i was 14
stock worked when i was young too
