Old 03-26-2013, 11:57 PM   #1
birdistheword
birdistheword's Avatar
Woodgrain trim questions
Anyone know any tips or advice to get the woodgrain sticker trim off? I have all the original trim and I'm trying to redo it.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 03-27-2013, 05:27 AM   #2
JimKshortstep4x4
Re: Woodgrain trim questions
I use an industrial model "hair dryer" to heat the woodgrain and it peels off very easily. You have to play with the heat as it works better if you don't overheat it. I don't know if a regular hair dryer will work but you could try one if you have access to it.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-27-2013, 06:57 AM   #3
SuperC10Tex
SuperC10Tex's Avatar
I used "Goof-off", just spread it out in small sigments (2 ft at a time) at a time....let sit for about five-ten minutes...off it comes (keep off the painted areas, unless you are repainting). Also get a window screen spline tool, has two different size rollers...helps roll/work out those dings in the trim while you have it off!!! Good Luck!!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
