Old 03-27-2013, 12:23 AM   #1
Bierkan
Bierkan's Avatar
Fuel Lines
I finally got my 50 back home. Next up is installing new brake and fuel lines.
Tank has been relocated to rear of the axle, and the old fuel line was suspect, so I want to route a new line up to the carb.
Where would be a good primer for a newb such as me to follow? Any specific materials I should use or avoid?
For now I can use the brake lines that were on the truck (72 C10 Chassis), but eventually I'll want to bend new and remove some of the crazy bends put into the main line from shortening the chassis. I also have a power brake booster to install, which will move the master out some.
Thanks in advance!
James "Bierkan" Vierkant
1950 3100 on a 1972 C10 Chassis
Truck Blog
Motorcycle Blog
Bierkan is offline   Reply With Quote
