Old 03-27-2013, 01:02 AM   #1
Bulldog88
Fuel problem with a ls swap please help
Im having a issue with keeping fuel at the rail, im using a fuel cell thats vented, aeromotive regulator, walbro pump, the pump turn on everytime I turn the key but I have floor the gas pedal for it to start up other wise the engine wont fire up is has a ls1 intake with the built in regulator on it, is it possible that the regulator on the on the intake has gone bad and doesnt hold fuel pressure?
Bulldog88 is offline   Reply With Quote
Old 03-27-2013, 04:45 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Fuel problem with a ls swap please help
You have a 97-98 Corvette fuel rail with both feed and return lines? That's the only LS1 fuel rail that has a built in regulator. Camaros with returnless rails dont have a regulator, just a pulsator. Have you verified that it isn't holding pressure with a gauge? Usually having to floor the pedal to get it to start means you're getting too much fuel and flooring it puts it in clear flood mode.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-27-2013, 11:01 AM   #3
Bulldog88
I have the Ls1 intake that came from a camaro, which only has a feed my return is at the regulator
Old 03-27-2013, 12:16 PM   #4
joesgreen67
joesgreen67's Avatar
Originally Posted by ls1nova71 View Post
Have you verified that it isn't holding pressure with a gauge?Posted via Mobile Device
^^^^^^ Exactly what I was thinking! You really need to check your fuel pressure before you try to diagnose.
joesgreen67 is offline   Reply With Quote
Old 03-27-2013, 02:07 PM   #5
Bulldog88
Is t possible that its doing ths because the o2 sensors are not installed yet in the exhaust , the fuel regulator is brand new and set at 60psi
Old 03-27-2013, 03:17 PM   #6
joesgreen67
No, I ran mine without o2 sensors hooked up (until I got to the muffler shop).
Even though you have a new fuel reg. you REALLY need to check your fuel pressure at the RAIL.
How are you determining fuel pressure?
Your prob. gonna find you do not have enough pressure. I know your saying the regulator is new BUT ......I had both o2 sensors that had a problem right out of the box! I bought Denso brand o2 sensors and my CEL hasnt come on since.
Just because it's new doesnt mean its good.
