Hard to start after sitting
So my truck runs really good! passed smog test better than my imports! trouble I've always had with this truck is after it sits 3 or four days,really have to pump it 10 times or so, crank it over 4 times maybe ,then fires right up, I changed the carb about 15 years ago,think the old one was bad,anyways I'm pretty sure the automatic choke is bad,doesn't seem to move the top plate closed,what else could it be? once the truck starts,runs great,did a complete tune up in Dec. Thanks John
Re: Hard to start after sitting
Nice engine. Real clean
My theory is the float bowls drain after sitting so you have to crank it till it fills and pump till the accelarator pump gives a squirt. There's some plugs underneath the quadrajet that leaks Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Makes sense,anyway to fix those? plugs?
Thanks John! |
have the same problem except mine is worst mind only takes about 7 hours of sitting before i get it to start right away, i always got to pump it to start in the morning. i was told it was the float too.
~When In Doubt Go Lower~ |
So basically a rebuild kit,oh joy,had a 56 Packard that did the same thing,but worse! had a feeling it was in the carb, forgot ,but where does the gas drain to? intake manifold I guess,luckily there's sooooo much room to work on this engine, need to get the ID plate numbers and order a kit
Thanks John! |
Had that problem also found that it was a crack in the fuel line hose, air was getting in
TEXAS BOYZ WITH CHEVY TOYZ ![]() |
Don't Crush em Restore em
I had this same problem and mine was the fuel pump, I would allow bleed by in the pump itself, so the carb and lines up the carb would all drain out.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() |
Just adjust the choke so it closes when you start it. It has a lean and rich mark on it.
THere's 3 screws on the black cap on the side of your carb. Loosen them and turn the cap. |
Here's a link I forgot to add that explains the choke.
http://www.vetteprojects.com/kstyer/quadrajet_2.htm |
On the bottom the common fix is to epoxy the holes to seal the plugs up
Another issue is evaporation. The modern fuels tend to disappear into the atmosphere a bit more than they used to. Last time I spilled some gas on the ground the puddle dried in an hour.
