Old 03-27-2013, 07:48 AM   #1
BigDaddyV
BigDaddyV's Avatar
Fuel pump 454?
Heya guys / n gals
Does anyone know if I can run a 40gph fuel pump on a 454 with a 800cfm, 1406 edelbrock carb on my 454? The motor has a mild cam (RV cam)
and long tube headers but thats about it. I've been narrowing down small issues trying to get my monster on the road. So any help would be greatly appreciated.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 03-27-2013, 08:09 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Fuel pump 454?
just be sure to run a pressure reg but 800cfm sounds a bit much for the rv cam
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-27-2013, 08:39 AM   #3
70CHEVYBB
70CHEVYBB's Avatar
Re: Fuel pump 454?
1406 is a 600 cfm carb. 1412 is a 800 cfm and 1812 is the 800 cfm thunder series.
70CHEVYBB is offline   Reply With Quote
Old 03-27-2013, 08:55 AM   #4
BigDaddyV
BigDaddyV's Avatar
Re: Fuel pump 454?
cool i was just going off what I was told. guess I should have done the research.
I have a 1406 and a 1409. so both are 600cfm correct?
Old 03-27-2013, 08:57 AM   #5
BigDaddyV
BigDaddyV's Avatar
Re: Fuel pump 454?
The reason I ask is all the pumps I have looked up for the 454 are 120gph. and the one I have on my 350 in my 85 is 40gph. both are 5-6psi. Ithats the only difference I can find between them. but the 120gph seems a bit much.
Old 03-27-2013, 03:52 PM   #6
BigDaddyV
BigDaddyV's Avatar
Re: Fuel pump 454?
bump
Old 03-27-2013, 05:24 PM   #7
72chevyk10
I built it
72chevyk10's Avatar
Re: Fuel pump 454?
i personally couldnt get a factory replacement pump to run the engine right. it would always run out of fuel after a few seconds of wide open. so i got the summit 110gph with a regulator set for 5psi and i can hold it to the floor all day and it does fine. edelbrock 1411 (750cfm) and "rv" cam.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 03-27-2013, 07:49 PM   #8
BigDaddyV
BigDaddyV's Avatar
Re: Fuel pump 454?
Thanks bud that helps alot. Im gonna try something like that.
Old 03-27-2013, 08:14 PM   #9
LONGHAIR
Re: Fuel pump 454?
Use a regulator no matter which pump you choose. Edelbrock carburetors are known to be sensitive to fuel pressure.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-02-2013, 06:37 PM   #10
BigDaddyV
BigDaddyV's Avatar
Re: Fuel pump 454?
ok I got the fuel issue taken care of. and now I got no fire. Damn it man. one thing right after another. She fired first time when I changed the fuel pump and the reg. saw a leak so I shut her down to fix it. And now nothing.... just spin spin spin..... AAAAAAAAaaaaaahhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!
Old 04-02-2013, 10:09 PM   #11
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Fuel pump 454?
IF all you did was fuel pump, it's something simple. Wire wiggled of the HEI? Were you under the dash? Pull a plug and see if there is any spark. For any reason did you mess with the starter wires?
prostreetC-10 is offline   Reply With Quote
Old 04-05-2013, 09:53 AM   #12
BigDaddyV
BigDaddyV's Avatar
Re: Fuel pump 454?
I did find that my big starter wire has been chewed on by a mouse.... Grrr.
I do have spark at the plugs. I did the plug trick and it arc's real nice and pretty.... I still have flooding issues. Im gonna try another Carb. 1411 edelbrock.
