Old 03-27-2013, 09:09 AM   #1
lucifer
lucifer's Avatar
Cool rear axel
Need some help identifying the rear end I need. I have a 65 Burb and want to convert to 5 bolt axels. Does the rear end I need come in 70-72 trucks??
I want the same width rear end as I currently haven but with 5 bolt axels.
ANy help??
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 03-27-2013, 10:31 AM   #2
Swed
Swed's Avatar
Re: rear axel
Hello,
There is several threads about this,
I googled it and found this,
http://67-72chevytrucks.com/vboard/s...d.php?t=456299
I have my 62 c10 axles redrilled because it isnt so easy to find 5 lug axles to put in. I payed $140 for both axles.
Johnny G
-----------Vehicles--------------
* Chevrolet C-10 Stepside 1962
* Audi A4 Avant Quattro TDI 2008
* Sachs Compact 50cc 1967
Swed is offline   Reply With Quote
Old 03-27-2013, 12:57 PM   #3
65Gregg
65Gregg's Avatar
Re: rear axel
I just did this conversion, I ordered my axles from Summit's eBay site for $270.00 with free shipping. I also changed the ring and pinion which I ordered from RMS Drivetrain. You would need drums w/the 5 lug pattern if you go this route. Summits part number is MSR-A3065GMT5, these are Moser axles. If you don't change the anything but axles it's a breeze just pull the c clips remove and put in the new ones.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 03-27-2013, 01:08 PM   #4
lucifer
lucifer's Avatar
Cool Re: rear axel
Thanx for all the info. Very helpfull
Old 03-27-2013, 04:08 PM   #5
kieth
kieth's Avatar
Re: rear axel
I had mine redrilled as well, they will also have to turn the center hub down so the brake drums for 5 lugs will fit. here is a link to a picture::::
http://kieth.smugmug.com/Trucks/66-G...4686&k=8bbRfcq
kieth is offline   Reply With Quote
Old 03-27-2013, 07:36 PM   #6
62 mark
62 mark's Avatar
Re: rear axel
The 70-72 axle will bolt right in to your truck...only thing is it is 1.5 inches wider. On my truck it was more work because 62 axles have different perch-track arm spots.welded new ones on and bolted it in,and swapped the front crossmember from same parts truck with disc brakes. The reason i didn't just drill my axle shafts was i wanted a better gear ratio and the newer style axle.
62 mark is offline   Reply With Quote
