Old 03-27-2013, 12:40 PM   #1
kdubsk10
Electrical help
So here's my problem the fuse box is not getting power but the alt and starter are , headlights only work when motor is running, turn singles and four ways work as well as break lights but no marker lights front or rear , gauges all work but no gauge panel lights except high beam indicator is this one problem or diff ones it's a 85 silverado k10 single cab long bed 350 sbc this it the last thing I need to figure out to get it inspected ne one have ne ideas that this could be
kdubsk10 is offline   Reply With Quote
Old 03-27-2013, 12:56 PM   #2
Psycho_SWB
Re: Electrical help
I would start by checking all of my fuses.
Psycho_SWB is offline   Reply With Quote
Old 03-27-2013, 02:16 PM   #3
kdubsk10
Re: Electrical help
I did all of them are good I have to pull them bc there's no power to the fuse block I read on google someone hade the same problem and the only answer was to tighten the block on the fife wall witch u did and it's tight
Old 03-27-2013, 03:26 PM   #4
hatzie
Moderator
hatzie's Avatar
Re: Electrical help
You likely have a burnt fusible link at the starter.
According to GM, in 1985, power feed to the fuse block is a 3mm˛ (@12awg) red wire circuit #2J. The red wire is protected by the smaller 1mm˛ (@18awg) fusible link at the starter.
The 1985 GM wiring diagrams are in my signature.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-27-2013, 03:44 PM   #5
hyatt
Re: Electrical help
I agree fuze link probally burnt
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 03-27-2013, 05:13 PM   #6
kdubsk10
Re: Electrical help
Ok thanks everyone lets hope that's it haha
Old 03-27-2013, 11:29 PM   #7
mrolds88
Re: Electrical help
Doesn't a the fuse block get fed off the distribution block in the middle of the firewall?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-27-2013, 11:36 PM   #8
JellyBeanDriver
Re: Electrical help
There's more than one feed and only one of them goes through that distribution block.
JellyBeanDriver is offline   Reply With Quote
Old 03-29-2013, 07:17 PM   #9
kdubsk10
Re: Electrical help
Ok so I checked the block on the fire wall every thing is good I'm starting to think its that switch since everything works but the marker lights and the dash lights ne one have ne other ideas what it could be......
Old 03-29-2013, 07:51 PM   #10
hatzie
Moderator
hatzie's Avatar
Re: Electrical help
The junction block is only part of the main harness feed.
In 1985 GM used two fusible links at the starter. They're separate from the junction block.
Old 03-29-2013, 07:58 PM   #11
kdubsk10
Re: Electrical help
I checked them there getting power
Old 03-29-2013, 11:57 PM   #12
JellyBeanDriver
Re: Electrical help
How did you check the fusible links?
Those test lights where you clip one end to ground and the other end is pointy is great. You can pierce insulation and see if the wire is hot AND the lamp gives enough of a load to prevent false readings.
Old 03-30-2013, 03:31 AM   #13
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Electrical help
Check the fuseable link that is by the firewall between the brake booster and the engine. I have a couple of these go out and now I carry a couple with me in that truck all of the time. I just went to the salvage yard and cut a couple out of the leftover wiring harnesses that were in the trucks.
Frank
piecesparts is offline   Reply With Quote
Old 03-30-2013, 09:23 AM   #14
wraprail
wraprail's Avatar
Re: Electrical help
If you are having to replace a fuseable link more than once you should look for the short or overload or whatever is causing it. It's not
wraprail is offline   Reply With Quote
Old 03-30-2013, 03:45 PM   #15
piecesparts
Re: Electrical help
I only had to do it once, but having the extra in the glovebox, is a comfort to know vice having someone haul you home on a flatbed. Especially if you are 3000 miles from home on a trip.
Frank
