03-27-2013, 01:43 PM | #1 |
1966 Wire Install Help Needed misc connections
I have installed a wire block but need help ID'ing some wire connections:
1)Block has 3 wire terminals in the right of the fuses, what / where do the Green and Brown wires connect to? See Picture; 2)The Pink and Brown with the instruments lights connect to? 3)Two terminals at the bottom of the steering column connects to? 4)which wire connects to the brake switch? 5)White and Orange wire terminals next to the switch harness? [ATTACH]1083191[/ATTACH Last edited by MikeFike; 03-27-2013 at 01:51 PM. |
03-27-2013, 01:49 PM | #2 |
Re: 1966 Wire Install Help Needed misc connections
Pink and brown connector in your last pic connects to the instrument panel fuel gauge. You should have a similar one on the other side that connects to the panel's temp gauge.
03-27-2013, 02:04 PM | #3 |
Excellent, thanks Brad.
03-27-2013, 07:59 PM | #4 |
The round switch is the brake light switch, when the pedal moves away from it and the plunger comes out, they go on. It appears on mine that it's orange and white also, so that's probably those two spade connections. Doesn't matter what side they go on, just plug them in.
Also attached is a pic of my ignition switch, best i could get it. I can't tell where the two "V" shaped pronged square item you took a pic of is located, if on the steering column, maybe be reverse lights? Here are some pics of mine, and as best a shot of the ignition switch as i could get. Let me know where the square v prong thing is and i'll go look. Also, as mentioned, i know the back of 2 of the gauges look that way, you can tell because the gauge cluster has it's own harness, so wires going to it are all taped together.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
03-27-2013, 08:01 PM | #5 |
First pic is orange and white also going to dome light, single plug though, nothing to do with brake lights.
03-29-2013, 12:33 PM | #6 |
Did you get all of you questions answered ??
Larry 84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles. "It's a sorry man who can't find his wife a good job" |
03-30-2013, 12:50 AM | #7 |
Three were answered , I will attach some new pictures tomorrow that were requests for better pictures to help some folks.
03-30-2013, 01:31 AM | #8 |
Here is a wiring diagram for a 66. Hope this helps..
03-30-2013, 04:15 PM | #9 |
Cortcomp,
Thanks for the info, a great deal of help. RE: '"V" shaped pronged' I have attached better pictures, any help will be appreciated. It is at the base of the Colum steering. |
03-30-2013, 04:45 PM | #10 |
Looks like a neutral safety switch..
Posted via Mobile Device |
03-31-2013, 03:32 PM | #11 |
I will look at mine tonight, i dont recall having a switch there but there have been many hands in my truck before i got it.
03-31-2013, 04:57 PM | #12 |
Its a neutral safety switch for and automatic trans setup. Mine has that.
Tags |
block wire, wiring |
