03-27-2013, 05:57 PM | #1 |
Anyone go with dual master cyl, disc and drum?
I installed the 11 inch rotors on the front and using the original drum brakes on the rear. I was planning on going with power brakes but thinking about the 68 Corvette master cylinder without power. Anyone do this type of setup? And how's it working for you? Did you use a proportioning valve? Just a few questions......thx all.
03-27-2013, 07:40 PM | #2 |
Re: Anyone go with dual master cyl, disc and drum?
I HAVE THAT SET-UP ON MY TRUCK, I USED A BOOSTER/MASTER CYL. FROM A 85 CHEV. TRUCK. THE PORP. VALVE WAS ATTACHED TO THE MASTER CYLINDER. IT WORKS GREAT.
03-27-2013, 07:44 PM | #3 |
Watch out for your cornhole !
I used every single line and component from an 80 model truck. It all bolted in. Everything from the master cylinder on the firewall to the brake hoses.
Posted via Mobile Device |
