blazer brackets in a truck?
I bought a set of 72 buckets off a fellow board member and they came with the blazer passenger bracket. Anyone used these in their truck? I'm guessing it is no issue, but I am curious if it is even usable or the tilt hits the dash before you get any advantage out of them. I have moved my gas tank to under the bed if that helps with opinions on using them. Thanks!
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
![]() Join Date: Oct 2012
Re: blazer brackets in a truck?
I put them in my '72 w/gas tank....just had to bend the handle a little upwards, tilt forward not an issue. No gas tank will make it better, good luck!!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch" ![]() "An intellectual is a man who takes more words than necessary to tell more than he knows" |
Thanks! These are in good shape and didn't want to order regular since these are so nice. Anyone got good pictures of all the hardware? Also will i have to drill new holes? The cab was originally a bench.
![]() Join Date: Oct 2009
i prefer blazer brackets - nice to be able to at least lean the seat fwd. I bought some from jonathan (va72c10). I'd stick em in, if for any reason you don't like em, it's a short job to swap em to the standard brackets if you choose to buy them later.
Pics of the tilt forward....do a search for "Bucket Seats" you will find all you need about installation!!
Here is a thread that was moved to FAQ.
The bucket seats use different holes for the most part and there are underbody brackets and a crossbrace present on factory A50 (bucket seat) trucks. http://67-72chevytrucks.com/vboard/s...ht=bucket+seat
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
