Old 03-27-2013, 09:54 PM   #1
Gigem
Gigem's Avatar
Intermittent voltage gauge
My new voltmeter gauge only works once in a while. Usually pegged all the way to the left, no volts. I know it is a gauge problem, not a charging system issue.
Feels like a loose wire or bad ground. Honestly, I have no idea what wire to look for. Any ideas? What color wire, and where do I look?
Thanks!
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 03-28-2013, 10:32 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Intermittent voltage gauge
Thanks!
could it be a idiot sender?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-28-2013, 11:34 AM   #3
Gigem
Gigem's Avatar
Maybe - or perhaps an idiot owner!
I honestly don't even know how this hooks up - what kind of sender is there? I did not do this install...
Old 03-28-2013, 11:40 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Make sure you have ground wire from block to firewall on rear pass side head
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-28-2013, 11:52 AM   #5
Skunksmash
Skunksmash's Avatar
I hate having to do this myself, but I'd probably start by pulling the gauge cluster and soldering each point of contact for the new wires on the new gauge. At the gauge itself, and wherever they connect. Those little connectors they use are too hard to tell if they're making good connection sometimes, so solder is a way to cut that out of the equation.
Skunksmash is offline   Reply With Quote
Old 03-28-2013, 12:30 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
no me ,oops it's a wire,not a sender unit like oil or temp
my 78 it was orange and brown for Idiot light
John
Old 03-28-2013, 12:32 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
Gigem.....you really should invest in a set of triple gauges for underdash like stewart warner or sunpro etc
1991 GMC Jimmy 4x4
