Old 03-27-2013, 11:14 PM   #1
UATahoe
Need help with motor mounts
Ok, I am in the middle of a motor swap in my 87 R10. The old TBI 350 is gone and a 383 vortec stroker is going in its place. I purchased new motor mounts that mount to the frame. I forgot however to remove the motor mounts that were attached to the block. Where in the world do I find replacements? The new motor doesn't have them. Any help is appreciated. I have looked in all the places I know but can only find the mounts that mount to the frame.
UATahoe is offline   Reply With Quote
Old 03-27-2013, 11:51 PM   #2
KrazyRay
KrazyRay's Avatar
Re: Need help with motor mounts
Sounds like you need clam shells.
KrazyRay is offline   Reply With Quote
Old 03-28-2013, 12:08 AM   #3
UATahoe
I thought the clam shell mounted to the frame? I need the other half that mounts to the engine block and slips over the clamshells
Old 03-28-2013, 12:40 AM   #4
LynnJr
http://www.ebay.com/itm/Engine-Motor...ccbb7e&vxp=mtr
LynnJr is offline   Reply With Quote
Old 03-28-2013, 12:43 AM   #5
king-918
king-918's Avatar
THis?
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 03-28-2013, 12:51 AM   #6
LynnJr
That bolts to the frame.He needs the all steel part that bolts to the block if I read his post right.
Old 03-28-2013, 12:58 AM   #7
king-918
king-918's Avatar
Spam!
<----Christopher
Oklahoma
Old 03-28-2013, 01:01 AM   #8
mtnsackett
mtnsackett's Avatar
I would try checking local salvage yards or car-part.com
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world!
mtnsackett is offline   Reply With Quote
Old 03-28-2013, 08:26 AM   #9
UATahoe
That is correct. I need the bracket that bolts to the block. I have new clamshell motor mounts installed already. Just need the piece that fits over the clam shell and the bolt then goes through
Old 03-28-2013, 10:24 AM   #10
Shyguy
Junior Member
Shyguy's Avatar
Have you checked your local parts stores, that is where we normally get them for 67-72 trucks.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-28-2013, 10:47 AM   #11
UATahoe
Havent yet. Just checked their websites. Only thing it would return was the clamshell that mounts to the frame. I have to stop in there today. I will see what they have.
Old 03-28-2013, 11:11 AM   #12
KrazyRay
KrazyRay's Avatar
We have been calling the piece that bolts to the block a "clam shell". I guess that would make the rubber mount the "clam". Here's a pic of a set of clam shells:
Old 03-28-2013, 11:22 AM   #13
UATahoe
LOL i got ya now. Yes, that is exactly what i am looking for. Those mount to the three mounts on the block.
Old 03-28-2013, 11:24 AM   #14
UATahoe
One other question, are they only available in all steel? Is that factory? For some reason i was thinking there was rubber too but i really have no idea.
Old 03-28-2013, 11:29 AM   #15
KrazyRay
KrazyRay's Avatar
These are factory and they are all steel. I have a bucket full of these as I take them off the motor before they go to the engine shop. The only rubber would be the motor mount itself as seen in post #5.
Old 03-28-2013, 11:53 AM   #16
UATahoe
Sweet. I am guessing they will bolt up to any small block chevy right? Do you have the necessary hardware for installing them as well? Guessing just 3 bolts per side?
Old 03-28-2013, 12:10 PM   #17
KrazyRay
KrazyRay's Avatar
I do not have any bolts right now, but they use standard bolts.
Old 03-28-2013, 12:12 PM   #18
LynnJr
They bolt up to any smallblock.
The ones in the e-bay ad post #4 are way over-priced at $27 I just found the picture and wanted to show you it.Those also have a reinforcing plate in them if you look closely.They added that as some of them will have cracks around the bolt holes.
They use 3/8 coarse bolts to hold them to the block and it is best to use lock washers on them so the bolts don't back out.
Your best bet would be one of the discount auto wreckers.They are dirt cheap there and often times you will find them laying on the ground already unbolted.
Old 03-28-2013, 12:43 PM   #19
UATahoe
Ray, i am going to check the local yard today. If i dont find anything i will let you know because i definitely need a set.
Old 03-28-2013, 01:12 PM   #20
77chevyinline6
77chevyinline6's Avatar
summit had them just look for "motor mount brackets" i got a set from them because i went from a inline 6 to a 350..
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 03-28-2013, 01:19 PM   #21
UATahoe
I tried looking on Summit. Only thing it would pull up was the mount to the frame. Part number by chance?
Old 03-28-2013, 01:25 PM   #22
77chevyinline6
http://www.summitracing.com/parts/oe...make/chevrolet
here ya go
Old 03-28-2013, 01:32 PM   #23
UATahoe
Actuallly found those but for some reason it cuts off application in 1983. Wasnt sure why that was. My truck is an 87.
