Sisyphus was my mentor!
![]() Join Date: Sep 2002
Hey all. My appologies to whomever I borowed this pic from BUT its a good view. Its not my truck but it is the same area. I'm in the process of changing out my passenger side rocker-BUT I'm having trouble-at the rear i drilled out the spotwelds easy-its loose there and at the front i've remoced the two bolts in circles #2 & i've drilled the spotwelds at #1 BUT it wont pull loose-what else is holding it in place? Is what is holding it in place inside circle #3 OR is it on the backside? Do i need the fender off to un-do what is holding me back? I'm flying blind here & i'm open to all suggestions-Thanx!
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
I'm a crazy guy, but when I did my rockers, I tried to do the spot weld drill trick, but then found it was much easier to take a air chisel and go up under the rocker and pry them from the cab.
A pic of the mess.
Not really sure, but there is a whole row of spot welds along the very bottom edge of the rocker that will need to be drilled out or as racedevil said he airchiseled them.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
There is also a row of spot welds along the top(at least there were on mine). I think they were about half an inch from the lip for the weatherstripping.
Low68 ![]()
Build Thread |
ttt
check for spotwelds at loc#3 i believe there is 2 or 3.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
ttt-one more time...
huh?
![]() Join Date: May 2000
That garage floor looks familiar Racedvl
![]() ttt
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
dern scanner....
scanner is broke.... I can email the full size picture if this doesn't turn out.
other view
the x's are spot welds
Dirt Dobber,
From what book did you get those photos? I need one of those books! Does it show spot weld locations for the bed sides? Thanks Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
#13 | |
Ditto!!! |
#14 | |
I dunno how you would rembember. . . . . . . ![]() |
#15 |
Those came out of my Factory Assembly Manual....it has everything...
#16 |
wow Dirt Dobber - those pics show exactly what I gotta do. Thanx to all - I'll try & give it a shot tonight & I'll let you know how it goes. Tahnx again!
