Where does the lower steering column seal fit?
Where does the lower column seal (in the bottom of the picture) fit in relation to the firewall pad, the firewall rubber seal, and the shaft mounting plate?
thanks The Fixer |
Re: Where does the lower steering column seal fit?
The seal that is on the column is the only one that you need. I believe that the seal you are asking about is for some of the larger trucks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Thanks Jim. Maybe I bought it needlessly.
Does anyone else have an idea? The hole in the seal I am asking about is about a 1/4 smaller in diameter than the steering shaft. But is is the same size as the brake booster rod hole in the firewall! thanks The Fixer |
There's only one location to seal,where the column exits the cab,so only the one seal.
