03-28-2013, 08:02 PM | #1 |
Monroe Shocks
I just ordered a set of front and rear shocks for the '67. The box with the front shocks had what I expected in it; a shock and stud. The box for the rear shocks had a shock and a .... I don't know. Can some one tell me what the gray round bushing looking thing in the pic is? It seems to be metal. Been a while since I replaced shocks!
03-28-2013, 08:35 PM | #2 |
Re: Monroe Shocks
It looks to be a spacer to help adjust the shock angle, if need be?
03-28-2013, 08:39 PM | #3 |
Re: Monroe Shocks
03-28-2013, 08:56 PM | #4 |
Re: Monroe Shocks
On my 69 Blazer those spacers went up on the front shocks.
03-28-2013, 09:38 PM | #5 |
Re: Monroe Shocks
it's a spacer so the shock will fit different vehicles. if you truck dosn't have them then don't worry about it.
03-28-2013, 09:54 PM | #6 |
Re: Monroe Shocks
Mine had those too. I trashed them.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
03-29-2013, 12:21 AM | #7 |
Re: Monroe Shocks
If I remember correctly, that shock part number also fits the front of the 4x4 trucks/blazers. But maybe the later ones with the quad shock front shock option. Anyways, that is a spacers that makes them fit on the front on the 4x4 chassis'.
Throw them away, or save them as they make really good spacers for other random things. I have used them several times for carrier bearing spacers after lowering a truck(non-GM). |
03-29-2013, 01:51 AM | #8 |
Re: Monroe Shocks
What's the process to change the shocks? Do you have to jack the truck up or have any special tools to compress the shocks or anything else like that?
Posted via Mobile Device |
03-29-2013, 01:53 AM | #9 | |
Re: Monroe Shocks
03-29-2013, 08:59 AM | #10 |
Re: Monroe Shocks
03-29-2013, 09:01 AM | #11 |
Re: Monroe Shocks
Not sure, have not checked out the manual or asked here yet. Maybe someone else will answer that for us. I would like to know too!
03-29-2013, 09:03 AM | #12 | |
Re: Monroe Shocks
03-29-2013, 09:08 AM | #13 | |
Re: Monroe Shocks
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
03-29-2013, 09:27 AM | #14 |
Re: Monroe Shocks
Its not bad. I had trouble getting the front ones off, the right hand one the top nut simply would not budge. Had to cut it off with a cut-off wheel. Otherwise, its just nuts and bolts. Front you want it on jack stands and the wheels off. rear you can do on the ground if your truck sits stock and you are skinny enough. Mine is lowered a little and I'm far from skinny, so I put it on jack stands.
03-29-2013, 11:36 AM | #15 | |
Re: Monroe Shocks
03-29-2013, 12:00 PM | #16 | |
Re: Monroe Shocks
03-29-2013, 02:03 PM | #17 |
Re: Monroe Shocks
Yep, sprayed em and then had to use a breaker bar
03-29-2013, 10:55 PM | #18 | |
Re: Monroe Shocks
Then I spent about 3 hours with a cut off tool.
03-29-2013, 11:07 PM | #19 |
Re: Monroe Shocks
I just got lucky. Started spraying the front stud and bolt with PB Blaster yesterday, hit them with the impact wrench - 5 minutes later they were both off! Now putting that d@mn top stud back in took about 20 minutes, that lock nut on the back of the stud was tough and no room to get there...
03-29-2013, 11:11 PM | #20 | |
Re: Monroe Shocks
03-29-2013, 11:46 PM | #21 | |
Re: Monroe Shocks
lol
03-30-2013, 09:27 AM | #22 |
Re: Monroe Shocks
John-
I see in the photo the number for the rear shocks was 34944. What number front shocks did you use? I was also wanting to know you thought about the ride after the installation? I'm getting ready to buy a set of shocks for my original 1969 C10. Thanks Ron
1972 C30 Cheyenne Super 1971 C10 (Parts truck) |
03-31-2013, 12:01 AM | #23 | |
Re: Monroe Shocks
I don't do much heavy hauling, so if I had it to do over, I would put on shocks designed for a car instead of a light truck.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
03-31-2013, 09:38 AM | #24 |
Re: Monroe Shocks
The front shocks are MONROE # 34817. Don't know about the ride yet. I replaced the front shocks and springs, backed it out of the shop to turn it around and backed it back in to do the rear shocks and springs. I got everything off last night but I need new spring clamps. A couple of mine have MAJOR rust pitting, almost all the way through on the top ones. If my local O'reillys does not have them I will order them from LMC, about $25 for the set of 4 with the bolts too.
03-31-2013, 09:39 AM | #25 |
Re: Monroe Shocks
