Old 03-28-2013, 08:52 PM   #1
crewcabshorty
crewcabshorty's Avatar
dana 60 wobble
i ve been reading alot about death wobble on dana 60s.my story is i purchased my 87 crew , and it had terrible wobble, scarey, and i have replaced alot of things, steering shock first, then steering box and drag link. new 4 in lift springs with new u bolts. my question is, could my king pins be worn enough to cause some wobble? it is not as bad as it was when i bought it, but i want rid of it completely!
crewcabshorty is offline   Reply With Quote
Old 03-29-2013, 06:31 AM   #2
b454rat
Re: dana 60 wobble
Replace the kingpins, it's not hard or real expensive. Get a new washer, then use the old one to shim it up a little. It's usually the top that goes bad, the bottom has an actual bearing. If it turns real easy or has slop, time to replace it. If the kingpin itself is OK, don't worry bout replacing it. But if there is excessive pits or grooves, they are $10 each I think. been a couple years since I messed with one....I do have an extra 7/8" allen wrench of yah need....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-29-2013, 06:35 AM   #3
andrewmp6
Re: dana 60 wobble
B545rat hit the nail on the head.You have replaced everything else it should fix the death wobble you have.If not the last ditch will be a panhard bar but they make a kit for your truck.
andrewmp6 is offline   Reply With Quote
Old 03-29-2013, 06:42 AM   #4
jjzepplin
jjzepplin's Avatar
Re: dana 60 wobble
I had death wobble, "89 dana 60", replaced the stock stabilizer and still had it. I put on a dual rancho stabilizer and it's solid as heck now. I will now be a checking kingpins though just in case. I also have the steering box strengthening kit but you might want to take a look there too as death wobble is real bad on the frame behind the box??
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-29-2013, 09:38 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: dana 60 wobble
The king pins are probably good, it's the springs and poly bushings that really take the beating. Offroad Design sells the complete kit to do both sides for about 30 bucks or any GM or Dodge dealer should have the parts in stock. If your using a real heavy tire wheel combo or a tire above 35" tall you may want to look into a set of spring eliminator arms.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-29-2013, 09:49 AM   #6
Bhelton
Bhelton's Avatar
Re: dana 60 wobble
Try an alignment as well
Bhelton is offline   Reply With Quote
Old 03-29-2013, 09:55 AM   #7
BLAZERMAN
BLAZERMAN's Avatar
Re: dana 60 wobble
Here's a link to the kit I mentioned above, also if you do need the king pins they sell a complete rebuild kit that also replaces the lower bearing. http://www.offroaddesign.com/catalog...ng-bushing.htm
Old 03-29-2013, 09:56 AM   #8
obijuan
Re: dana 60 wobble
4wdfactory.com has been my preferred vendor for ten years now.
obijuan is offline   Reply With Quote
Old 03-30-2013, 11:26 AM   #9
Mr. 250r
Mr. 250r's Avatar
Re: dana 60 wobble
i would also go with the 4wdfactory kit although i haven't installed mine though ha i also went with their socket that fits the kingpin as opposed to the allen key but i think either will work fine
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 03-30-2013, 12:04 PM   #10
obijuan
Re: dana 60 wobble
if youre reallly cheap, a long lugnut will fit in it. then use a 7/8 box end wrench and a cheater bar.
Old 04-02-2013, 11:39 AM   #11
Orange Crate
Orange Crate's Avatar
Re: dana 60 wobble
Here are my results from using the lug nut trick. You can see it took the first two on the left to remove one K-pin and the third one I had to install a stud inside and cut it off because it was going to twist in half before the pin even moved. I won't use this method again, I will weld a plate to the pin and use a BFH and more heat (heat was used with the lug nut method)
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 04-02-2013, 05:58 PM   #12
b454rat
Re: dana 60 wobble
Why not buy the correct 7/8" allen wrench? I got one for $10 at Fastenal. I have two that I will probly never use again....
