So, I just finished tearing out all the old, rotted plywood from my 63, and I have a few questions regarding replacing it.
I can't afford a kit premade for replacing it, so I'm resorting to some DIY options. I plan on using 2x6's for my replacement wood, and without the metal strips that go between them. I was wondering how much should I plane off of the wood, what kind of gap should I leave between them, and if 2x6's are even the best option. For anyone who has done this before, how wide was the wood you used? Pictures are always appreciated! |
#16876
Re: About to replace the wood bed, have some questions!
Use 1 x (3/4" thick) lumber. Anything else will throw off your bed height. Thicker wood wont fit into the front roll pan either. Check out GMC Pauls for directions on how to make your own replacement wood. http://www.gmcpauls.com/47-72_BedWood_Info.htm
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
I also cut my bed myself using GMC paul's dimensions. It's not hard just use a scrap piece first to cut it right. It cost me about $80 to do it.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
Be carefull if planning on using treated lumber....some of the new chemicals will rust / eat metal.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks a bunch, that website will definitely help me a lot!
![]() Join Date: Apr 2011
Great site Sillyoldman! Thanks for posting that!
Getting ready to do the same myself. Got the wood today and plan to work on it the next couple of weekends.
Moderator
![]() Join Date: Dec 2012
Pressure treated lumber is no good as bedwood. The sun makes it crack,check,warp within 8-12 months, It's only good when in constant moisture/water. As a Dockbuilder by trade, ask me how i know.
Glad I got rid of the wood 20 years ago.....T6061 T-6 alum plate.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#11 | |
Moderator
also used pressure treated wood in my bed no problems at all just a ***** to cut
#13 |
Moderator
Did you paint it?
#14 |
#15 |
Moderator
I completely agree, I only want to do it once. What else would you suggest for a truck that is going to sit outside. I will paint it. Low cost is good, too!
#16 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I've seen some guys use that composite lumber before, that is maintenance free and will probably outlast the truck, only issue is the cost.
I called a lumber company and asked for Hicory/Pecan wood. Cut to my dimensions was $175. Picked up. Before you say anything, I gave them what GMCPaul had. It is a very hard wood,will weather well and take stain easily. This is what I'll do for my bed when I get to it. Posted via Mobile Device
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
