Old 03-29-2013, 01:43 AM   #1
INSIDIOUS '86
INSIDIOUS '86's Avatar
Got another truck. 78-74 something stepside
Well I bought this months ago but just got it home. Truck is a 78 frame with mixed year parts everywhere cab is original to the frame buys a Sierra grande gmc with some fat leaf springs in back and had some big 10 emblems stuck to the rear fenders and big elephant mirrors hacked into the side (what do you need one ton gear for a stepside shorty?) Needs bed wood and floor boards and wiring but its basically a shell right now. Plans are to get it painted but I'm keeping the cool white patina on the back tailgate and doing a sm465 manual conversion and dropping in a H/O 305 (exciting!) temporarily till I get my mystery motor dropped in. Trucks a non ac too! Thinking of cutting the front springs for a 3" drop up front and relocating rear hangers for 4" rear drop and getting rid of the silly two piece driveshaft.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-29-2013, 02:34 AM   #2
Reziel_1983
Reziel_1983's Avatar
Re: Got another truck. 78-74 something stepside
Cool truck... What color you going with?
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 03-29-2013, 02:37 AM   #3
INSIDIOUS '86
Not sure yet. Thinking of keeping it brown or maybe Hawaiian blue
Old 03-29-2013, 09:37 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
If you go with a SM-465 I don't think you can get rid of the two piece drive shaft because the SM-465 does not have a slip yoke.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-29-2013, 01:03 PM   #5
INSIDIOUS '86
You can with a slip yoke driveshaft kinda like the 4x4 driveshafts
Old 03-29-2013, 01:17 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
The Big 10 package was 3/4 ton springs all around, plus a bunch of other heavy duty parts. Larger brake booster, two piece drive shaft, wider rear brake drums, etc.
Doesn't make much sense on a half ton short wheelbase now does it?
The REAL reason that GM offered this package was to create a loop hole for emissions laws. By appropriately beefing up the truck to have a higher GVWR, the truck silently slipped out of the clutches of any catalytic converters or emissions spaghetti because it's GVWR rating was higher than that required to comply with emissions regulations. They save money on not having to install the emissions stuff, and the customer gets a simple and tough truck that's not choked out by band aid emissions junk. Win-win! Except for the EPA, I'm sure they didn't like this move.
My 77 has this package and I'm glad that it came that way. The best part is the dual exhaust transmission crossmember, rather than the funky catalytic converter crossmember that makes the exhaust a nightmare to fabricate.
My only complaint is the rear springs being way too stiff. Taking the overload springs out, plus another leaf that didn't seem to be doing much got the ride to be smooth enough.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-29-2013, 02:33 PM   #7
INSIDIOUS '86
I'm looking at it and it looks like that's possible since the booster looks longer than most but wouldn't gmc be "heavy half"?
Old 03-29-2013, 05:54 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Consider a metal bed floor. It's cheap and permanent compared to bed wood replacement. I used a long wide bed floor, modified of course, in the stepside I'm building now. It sure works out slick and cheap.
Old 03-29-2013, 06:27 PM   #9
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-29-2013, 07:34 PM   #10
GM-power
GM-power's Avatar
It would be. What rear end is in it? Certainly could be anything haha!
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 03-29-2013, 08:39 PM   #11
Pyrotechnic
Yes a GMC would be a Heavy Half. Chevy was Big 10. Someone probably had some fun with some stickers on your truck.
Either way, it all boils down to the "F44 Heavy Duty Chassis Equipment" option. That will be listed on the SPID sticker if it's still with the truck.
Old 03-29-2013, 09:00 PM   #12
cory d
cory d's Avatar
still left in the truck? thats like the first thing that little kids rip off. dibs your driveshaft! i can hardly fit u-joints into mine anymore. i love that hawaiian blue. match that with a white cab top and white on the tailgate and she will be a looker for sure. im between a light blue (not as bright as hawwaiian), brown, tan or some other browny tan color
cory d is offline   Reply With Quote
Old 03-30-2013, 02:41 AM   #13
INSIDIOUS '86
I will probably send in to the heritage center since the front inner fender was replaced and glove box is MIA It looks like a ten bolt in the rear but I will check the drums and front spindle thickness to see what size they are. Last I remove reading was 8000gross lbs which would be the weight of the truck + load =total weight? On a plate in by the door Stryker on cab.
I may make my own bed wood kit. Prob get some stainless hardware down the road and my buddy is a carpenter
Old 03-30-2013, 02:45 AM   #14
INSIDIOUS '86
Btw how do you fix this?! Both sides are this bad but everything else on this cab is real solid
Then I need floor panels. Where would you guys recommend? Brothers site has them but its confusing as hell as to what they are selling cause it doesn't look like the floor or what side at anything just generic "floor patch panel"
Other than front fender corners this truck is rather solid
Old 05-02-2013, 03:40 PM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
Try Top Banana, they are a vendor on here.
http://www.topbananaparts.com/vaf/pr...m=1080&year=29
The floors should be 01-0850-221 & 01-0850-222.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-02-2013, 04:27 PM   #16
INSIDIOUS '86
Thanks. I have a build thread going on in the projects and builds section
