Old 06-19-2003, 07:19 AM   #1
Richard Dobson
Cowl Hood Fit
I bought a cowl hood for a 71 chevy fleetside on which I am putting a 68 front clip. The hood pretty good but, looking straight on toward the front of the grill both sides hit the grill leaving about 1/2" gap between the bottom of the hood and the top of the grill. Can you guys on the board reassure me that this can be adjusted out or do I need to return the hood. The guy I bought it from said it was a goodmark hood, however the box it was in reads Tri Plus Company Inc. part no. EF 2093CW Steel Cowl Induction Hood. He said it was made by Goodmark from their tooling. Any input from the board will be greatly appreciated. Thanks, Headquarters.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 06-19-2003, 07:41 AM   #2
MOTHERTRUCKERS
71 hood on a 68 clip? is it a GMC?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 06-19-2003, 10:43 AM   #3
Richard Dobson
Cowl Hood
It's a 67-68 cowl hood. I am putting a 68 front clip on my 71 chevy truck. I purchased 68 aftermarket radiator support, cowl hood & I am using original 68 fenders but after assembly there is a gap between the middle of the grill and the bottom of the hood, the sides of the hood at the front meet the rad support leaving the gap I mentioned in the middle. Can this be adjusted out? Thanks for any board members input.
Richard Dobson
Old 06-19-2003, 11:01 AM   #4
griesel72
griesel72's Avatar
Pretty sure all goodmark hoods are stamped goodmark, mine was.
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 06-19-2003, 12:30 PM   #5
tom hand
CCRider
tom hand's Avatar
Hard to say without seeing it, but it sounds like you may want to try to move the latch down. Virtualy all aftermarket parts require some tweeking for any where close to a good fit
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-19-2003, 01:02 PM   #6
crazy4chevs
crazy4chevs's Avatar
sounds like you should go talk to him and find out what the deal is. Ive heard that the others fit like you describe and that the goodmark ones fit real good.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 06-19-2003, 01:37 PM   #7
kingparts
kingparts's Avatar
Goodmark hoods are stamped Goodmark right near the front near where the hood latch is located. When I was a dealer there were times I ordered from Goodmark and I received Triplus hoods. Never really had a problem with either one. Real good hoods.
1970 Chevrolet Suburban
1967 Chevrolet C/10 Shortbed Stepside
kingparts is offline   Reply With Quote
Old 06-19-2003, 01:45 PM   #8
Richard Dobson
Cowl Hood
The dealer I bought the hood from assured me all hoods are from Goodmark due to a lisence with Goodmark & Chevrolete, but Goodmark sold them to different dealers. I hope this isn't swamp land I have bought. Like I said before it hits on the corners in the front on the grill top but leaves a gap in the middle between the grill top & the bottom of the hood. Other than that it fits OK. Hopefully this can be adjusted out to give a good fit.
Richard Dobson
Old 06-19-2003, 03:54 PM   #9
kingparts
kingparts's Avatar
Give Goodmark a call and find out. (770)339-8557. Let us know.
Old 06-19-2003, 05:06 PM   #10
72MARIO
72MARIO's Avatar
I had the very same problem only worse.
I had a 1" gap in the middle and both corners hit. It was a Goodmark hood. the fit along the side's was totally s*it also the part you look at from the inside looked diffirent on bothe sides too. I have seen a few truck with pieces of foam at each coroner of the hood I could never figure out why. Now I understand. I took the hood back and told him for 800 Cdn that for that kinda of money it should need block sanding and primer. That's it !
he was cool with it. After all he does not make the hoods.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-19-2003, 07:10 PM   #11
MOTHERTRUCKERS
Their is some room for tweaking these hoods, Start with your front adjustable bumpers by unscrewing them up a little while screwing the catch pin into the plate and shutting the hood with even palm pressure accross the front edge, work slowly, it might take a few times adjusting and shutting but it will work the bow out of the hood. Next question are you sure your grill is straight and not bowed down? do you have the 67-8 center grill support and hood latch or a 67-8 support and a 69 or newer latch?
Old 06-20-2003, 02:08 AM   #12
Tim Christian
Tim Christian's Avatar
Sounds like you need a 67-68 hood by what I am reading. I sell both Goodmark and Tri-Plus hoods both are a very good hood but I don't get my Tri-Plus at Goodmark. I get them from a Tri-Plus wholesaler. I look forward to getting to talk to you this weekend at Super Chevy.
Tim Christian is offline   Reply With Quote
Old 06-20-2003, 03:05 AM   #13
cheyenneman
I think he said he has the right hood in a response. My buddy had this same problem after alot of work he got it close but it still has a small gap in the middle. I would try and adjust it but if your not happy, take it back.
cheyenneman is offline   Reply With Quote
Old 06-20-2003, 06:27 AM   #14
Tim Christian
Smile
cheyenneman, Yep Your right I did not read it right.
Old 06-23-2003, 09:14 AM   #15
Richard Dobson
Cowl Hood
I called Goodmark and a guy in sales said that a Tri Plus hood is made from the same tooling that a goodmark hood is made from. He said that they are made in Tiwan shipped in different boxes. I bought new hood hinges & springs from Tim Christian Saturday a the Bristol Super Chevy Show. He is a wealth of informatiion and I recomend anyone to buy aftermarket parts from him. A cool dude to say the least with great prices. Thanks for the help Saturday Tim. If anyone has any more suggestions on how to get my cowl hood to fit up better please give input. They are real sharp hoods & I hope to get the fit-up right without having to go back to a stock 67-68 hood that will fit properly.
Richard Dobson
Old 06-23-2003, 09:35 AM   #16
sider68
sider68's Avatar
Just how many companies in Taiwan are there making parts?I was under impression that next to N O S that Goodmark were the best as they had to meet actual G M specs.
The other companies used inferior steel and had there dies made from fibreglass moulds of parts which means they would be out a bit.Also I heard that in Taiwan they bought up old stamping dies from G M that could be worn out.I wish someone would clear this up for the members on this board
sider68 is offline   Reply With Quote
