Old 03-29-2013, 01:27 PM   #1
ulakovic22
Air Bag = how much drop?
I've seen this question answered before but I can't find the threads anymore. When changing from a coil spring to an air bag I believe there is an associated drop when the bag is at ride height. Most bags are around 6-8" at ride height, but I can't find what a factory compressed spring height is. Switching to air bags is what, a 2" drop? TIA!
ulakovic22 is offline   Reply With Quote
Old 03-29-2013, 02:00 PM   #2
jimmydean
jimmydean's Avatar
Re: Air Bag = how much drop?
I did both bags and spindles last time and I would say the bag was about 2.5-3" of drop on it's own. But it depends pn how the bag is mounted and what bag you are running.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-29-2013, 02:05 PM   #3
ulakovic22
Thanks, I was thinking it was about there. I'm going to be static for a while and wanted to look up some pictures for reference. I have D2600's and ECE 2.5" spindles on a factory 67. I guess I'm looking at about a 5" drop in the front then, thanks!
Old 03-29-2013, 02:37 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
I can ride with a stance of about a 6/7 drop with my DOMs...this is about 40 psi in the front and 30 in the rear. It's a little bumpy though...with 45-50 psi in the front, it goes up about an inch but rides much smoother.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-29-2013, 02:40 PM   #5
ulakovic22
Great looking Blazer and thanks for the info. Looks like you have an SBC in there, is that true?
Old 03-29-2013, 04:39 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Thanks! I need to snap some pics of it and update my thread...she's pretty much put together and running around now!
Yup...just a stock 350 out of some 80's burban I believe.
1970 2wd Blazer
Old 03-29-2013, 04:48 PM   #7
ulakovic22
Pics would be great, I have a BBC with aluminum heads and I'm only running an alternator so maybe our front end weight might be similar if you have a dressed cast iron long block. Thanks again for the info.
