Old 03-29-2013, 01:47 PM   #1
62lwbc10
wiring the heater and wipers
Hey All, I need to wire up the heater and am not sure about the connections. I think it might be a deluxe heater unit actually. I believe there are two wires coming off the fan. DO I simply take a wire from the ACCESSORY terminal of the ignition switch and use that to power the heater? or is it more complicated? Im not running the deluxe heater controls, just a simple two speed rotary switch.
Same question for the wiper motor. I have an electric motor installed and there seems to be three wires coming out of it. Not sure but maybe one of the wires may be for the washers which I will not use (I think the wiper motor is out of a more modern vehicle). I did get a correct wiper switch from Classic Parts, just not sure how to hook up the wires.
Any help with these two issues would be much appreciated.
Thanks,
Mark
62lwbc10 is offline   Reply With Quote
Old 03-29-2013, 11:52 PM   #2
sqrlnts
Re: wiring the heater and wipers
Before wiring the fan up I would apply 12 volts & a ground to the fan wires to see if it works. How many terminals on your rotary (variable resistor I assume) switch?
Not quite sure on the wipers. i would try the same 12 volts and ground to the wiper. you might have a two speed or a 1 speed wiper and a pump?
sqrlnts is offline   Reply With Quote
