03-29-2013, 08:14 PM | #1 |
GCVW... question.
Anyone one the GCVW ratings for a 1991 v3500? I can find the CVW but not that stat. thanks for the help.
levi |
03-29-2013, 09:32 PM | #2 |
Re: GCVW... question.
I'm not exactly sure what you are asking but here goes:
The GVW is the gross vehicle weight (weight of the truck plus what it can carry). You can find that here: http://www.gmheritagecenter.com/docs...olet-Truck.pdf I've attached the '87 info packet to avoid confusion with the '91 GMT400 models. It should be the same for a '91 R/V model. Now, GCVW normally refers to the Gross "Combined" weight, as in the weight of the truck and pulling a trailer. Is that what you are after? I am not familiar with the CVW as you have stated above. If that's the case we will have to find a trailering guide, which might take a bit of doing. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-29-2013, 11:38 PM | #3 |
yep combined weight is what im after
04-01-2013, 09:27 AM | #4 |
GCW varies based on powertrain options (engine and rear axle).
Chart is attached below ('87 shown to avoid confusion with the 1991 GMT400 models; '87 V should be the same as '91 V truck). http://www.lov2xlr8.no/brochures/gmc/87g_10.html K
04-02-2013, 09:50 PM | #5 |
WOW thanks... time to start upgradeing..
