03-29-2013, 08:16 PM | #1 |
Confirm this is a Deluxe Heater.....
Hello All can you please confirm this is a Deluxe heater? Its from my buddy's 55. In one of the pics you can see a copper coil that is on the partitioning valve that is hanging loose. Can you tell me where this goes? I dont intend to use the Deluxe heater switch, I will just have a simple switch for the fan unit and I plan to remove the control cables. I assume then I should manually open the partitioning valve and keep it there? If Im going to run the deluxe box as if it were standard (as I described above), should I just keep the block off plate on the pass side lower cowl (above the grill) or should I remove it and attach the fan unit with the fresh air connection. Im assuming I shouldnt do this but just confirming.....
ALso, see the pic of my firewall, which holes do you use for the heater hoses? THanks, Mark |
03-29-2013, 08:51 PM | #2 |
Re: Confirm this is a Deluxe Heater.....
I'm not seeing much in those photos. If the Task Force trucks are like the AD trucks the Deluxe heaters have a fresh air inlet while the standard heaters are more like a box on the inside of the firewall. I think the other key is the controls themselves.
Deluxe heater diagram http://chevy.oldcarmanualproject.com...cpctai108.html Standard (factory) heater diagram http://chevy.oldcarmanualproject.com...cpctai112.html This is referred to as a recirculating heater as it recirculates the air in the cab and doesn't bring in fresh air from the outside though the cowl grill. not
03-30-2013, 01:52 AM | #3 |
This is the Deluxe heater in my '57 GMC
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
