03-29-2013, 08:42 PM | #1 |
temp gauge
On my 5.3 swap my stock temp gauge is reading hot. Is there a resistor that can be put in the gauge to get the temp in the middle of the gauge. Has anyone else ran into this?
Posted via Mobile Device |
03-29-2013, 11:24 PM | #2 |
Truck and auto performance nut
Re: temp gauge
no...but 1st are you positive your motor isn't running warm and that its reading wrong? Did you fill it/top it off (motor) from the top radiator hose?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-30-2013, 08:41 AM | #3 |
Re: temp gauge
Ya i filled it up from upper hose. I havent let it get maxed out just a lil after half. Ill see what my true temp is today via heat gun and scan tool.
03-30-2013, 10:50 PM | #4 |
Re: temp gauge
Make sure all the steam is purged out. and water level is right
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-31-2013, 10:55 AM | #5 |
Re: temp gauge
Ya i checked with a live readout scanner my factory gauge is messed up. So all is good
