Old 06-19-2003, 09:47 AM   #1
Warbones
Navel Inspector
Warbones's Avatar
What is this?
No pics yet so this will be somewhat of a test. It looks kinda like part of the frame but bolt to the inside (underneath)rear cab corners and go to the where the cab body mounts are. In fact I beleive that the cab mount bolt, cushion ...ect goes through this part. What is this part called? Is there any welding needed to replace it? I am assuming the cab needs to be removed for this repair. If any one could post a picture of it. That would be great.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 06-19-2003, 09:53 AM   #2
Maximum Overdrive
December 21, 2012
Rear cab floor support and rear cab support cover I believe from your description. Never replaced one but chances are it needs welded.
Maximum Overdrive is offline   Reply With Quote
Old 06-19-2003, 02:50 PM   #3
VTKidder
Is this it?? The left side of the picture is the front cab mount support....
VTKidder is offline   Reply With Quote
Old 06-19-2003, 02:51 PM   #4
VTKidder
..........and this is the rear cab mount; cab corner on the right side of the pic to help with locating what we're looking at here. If that's what you have, welding is DEFINITELY in your future.
Old 06-19-2003, 03:48 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Why do we need to weld? THey are rivited to the frame.
Old 06-20-2003, 06:59 AM   #6
VTKidder
Guess I'm confused as to what we're talking about now...I thought he was talking about the front and rear cab mounts on the underside of the cab, not the mounts riveted to the frame.
Old 06-20-2003, 06:18 PM   #7
Warbones
Navel Inspector
Warbones's Avatar
It's some kind of brace. I took a picture of it. I will post it soon. It bolts on to the inside of the cab corner from underneath on one end and then goes from there to the cab mount.
WANTED 1967 IMPALA
Old 06-20-2003, 08:49 PM   #8
Class of 69
Class of 69's Avatar
Sounds like a home made rear cab mount huh?? I think VT has the right pic, Warbones just isn't seeing the cab mount in the pic...maybe a pic of a replacement mount alone would help.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 06-22-2003, 02:11 AM   #9
Warbones
Navel Inspector
Warbones's Avatar
It is the Rear Floor Support that I was seeing. Found it in the bowtiebits catalog. I was there the other day getting some trash guards for the cowl.
WANTED 1967 IMPALA
